Shaunhirst
Donnington Show.... Live engine swap in the main hall.
I was going to ask our main suspension supplier Koni what in that range would meet the requirement?
Share this post
Link to post
The questions is as per the donnington web site will I drive away?
Of course it will .......... fingers crossed. If any parts needed have more than one part number listed Eurocarparts will send all versions just to be safe.
Share this post
Link to post
Koni should be able to supply something but you would need to know the exact spec of your existing stuff. Maybe a step too far for the show?
Share this post
Link to post
Just been across to meet Shaun, 8)
Well up for it, and amazed at the response of the club. Been through a few things with him and think we have made a fairly comprehensive shopping list. Looks like Shaun has blagged...got sponsored a lot of kit, so think we will have a busy weekend. Only big purchase/ blag he need to sort is some nice shiney wheels....found out the ones he had lined up wouldn't have fitted correctly.
Just a quick question though...will the 1.6 sump fit the 2.0l ok? Just that the 1.6 sump has been shortened already. So was thinking of a straight swap?
Yes, i put my 1.6l sump on my 2.0l when i changed it.
Share this post
Link to post
Great news just been to Northampton to collect some wheels ready for powder coat tomorrow
Share this post
Link to post
What size tyre should I put on them they are
15" Alloys
4 x 108 PCD
Rim width 7J
Offset 37
Share this post
Link to post
Any car / van passing doncaster on Friday heading for the show that could collect some stuff from my house?
Share this post
Link to post
Haveing just had to replace the core plug covered by the bell housing which requires engine out.
Check if new core plugs are needed.
Share this post
Link to post
2 items not available from euro, oil spray bar and oil pump, available on eBay though shaun.
Share this post
Link to post
15" Alloys
4 x 108 PCD
Rim width 7J
Offset 37
205 x50 15 on 7 inch rims 195 will be alittle stetched my ops only but have run that combo for 10 years noprobs 18 /20 psi for pressures, is as much tyre /rim width as you need mowerman :acute:
Share this post
Link to post
