Donnington Show.... Live engine swap in the main hall.
I have been offered some shocks however to get them ordered I need confirmation of what works with the s7 series 3, can I again please ask for some help?
Size, spring etc
Talk to dave at Dampertech he should sort you out mower man :clapping:
Hi Guys, looks like this is going to be a show stopper. Any thought on changing big end bearings?
Just my thoughts but unless the crank is a known quantity "do not disturb"
Have a sneaky look at one big end and one main, maybe the centre main, then leave well alone with a "sit rep" findings.
Guest Shaunhirst
Oil spray bar, high pressure oil pump and shaft ordered from eBay, I have mailed them for urgent shipment
Guest Shaunhirst
Anyone able to available to help get this stuff to donnington on Friday going to have all sorts to shift
If you can get it over to my garage in Attercliffe Sheffield before Thursday afternoon, I will take as much as I can
Guest Shaunhirst
Do these engines take a fuel pressure regulator as I have an un used one from a c20xe build I did
Guest Shaunhirst
Yep I will bring as much as I can over on Thursday night, would be great to meet up before Friday anyway, I'm over at jct tomorrow around 6!! are you about? i could call in I am just up the road, please pm or text me your address
Guest Shaunhirst
Wheels are at the powder coater (gloss black) front grille and lamps being done in mat black, spill kits gloves Safty specs wipes and degreaser are with me, front grille lotus 7 badges (as on eBay) with Rhocar cut into them are being run tomorrow I will have as menu as I can blag.........
Guest Shaunhirst
Sorted a load of paint, red engine paint mix of acid etc prime and to coat black gloss and satin, and 20m of black heat wrap for the exhaust
What carbs are you running? If side drafts a pressure regulator maybe worth fitting certainly worth chucking in with the bits to take as you have it.
Im 5 minutes away from JCT
Amberley Garage
17-31 Attercliffe Common
Lower Don Valley
Sheffield
S9 2AE
If you pass Don Valley Stadium you will have just passed us.
