Supercharging An Mx5 Engine
richardm6994
More boring....58.5mm dia x 105mm deep hole with a 64.5mm x 5mm shoulder complete
Then 35mm chopped off the opposite end....this really was boring!!!
So back to machining.....this little game is called 'don't crash the traverser into the ali'.....because of the size and offset in the chuck, I've had to machine this in 2 stages.
Still along way to go...7 hours so far on this lump
Edited by steamer
I can't tell you guys just how much I admire the skills (& machinery!)
you can call on to turn a lump of metal into a thing of beauty.
I cant even work out how you can cut a half circle into a square block
leaving the other half square.....looks just like magic to me.....
Ive got a hacksaw & a blunt file....& I cant use either of them properly
Look at the chuck jaws on the lathe Bob.
It's a 4 jaw chuck and all 4 are independent of each other. This allows off Centre turning. The Centre of the Dia Rich is turning is the centre of the spindle.
Optical illusion mate. ;)
  • Like 2
This should give an idea of what the finished article will look like.
The spout at the rear is for the bypass valve to bolt onto and the outlet spigot will be machined out of amother price of aluminium and bolted on simply because the chuck jaws on my 4-jaw arnt big enough to machine both ends from the solid lump.
:crazy: My little lathe hasa 4 jaw independant chuck,it wouldn't handle any thing that big and I certainly have not got the skills to do it I'll carry on making pins and bushes[badly].If you go to the Harris v8 site you can watch a big cube of alloy being made into a crank case and block for their bike based 2.8 40 valve engine ,its incredible mower man
Still looks like magic to me.....
I can't build stuff like that, but I do design stuff.....
Ray needed a "top hat" for his new inlet to handle the air from 2 88mm Holset turbos
and accept a 102mm throttle body. There's nothing available off the shelf.
So I drew up a number of designs, knocked up prototypes in balsa wood, measured
cross sections & volume & used fluid dynamic formulae to make sure there are no pressure drops.
Here's the result....
The big alloy can is an ice water intercooler. I just wish we'd started with a bigger car
Edited by Bob Tucker
