Supercharging An Mx5 Engine
richardm6994
Looking good Rich...
Both of us had unexpected events this year....
Looking forward to popping across to see the progress. Looks like I'm in for a busy winter... Can't wait
38mm take-off spigot for the bypass valve tack welded into position........it has a small collar welded at the end to give the spigot a 'flared' end to prevent silicon pipes from popping off
Next job for the inlet pipe is to silver solder all of the flange joints and spigot joint to ensure no leakage and it makes the joint lines invisible when the whole assembly is painted.
  • 4 weeks later...
So next I have split the lump off the bottom of the throttle body and made a blanking plate to replace it.
Next job was to run a bead of silver solder into the joints of the inlet pipe to neaten things up and then polish back.
I've also added the 3rd fixing point at the bottom of the main bracket....
So my next mission is to secure the throttle body end of the inlet pipe to the block.....luckily there is a handy threaded boss in the block right next to the throttle body....
Rich you are getting me all excited but the mileage on the MX -5 i'm buying is pretty much an international phone number so it may not be wise to strap a blower on it!! mick :crazy: :80: :drinks:
