I am about to replace crossflow with ST170, I have the retroford alternator bracket to move the alternator to the righthand (inlet) side. I need a ACR type and believe it's a left hand version, does anyone know the part number or make model of Ford to get the correct model please.
Same for starter fitting to MT75 with 1.8 flywheel.
Thank you
Mark
DSC_0174_zpssg5f9rh7.jpgjust a heads up yours might be different but i found the only alt bracket i could get to fit was the gbs one with the small denso alt
Edited by tractor
Thanks Steve, the denso alternator requires different brackets to the one I have. Might be able modify if I cannot find the right alternator. Does it have the correct pulley?
Thanks Grim, that looks like the correct model and decent price.
Thanks Steve, I think Stephen I think problem has been solved.
Description/picture of pulley required -- may have one in the loft.
thank you, I will measure the shaft diameter when i get home. There was 2 versions 15mm and 17mm, with the ACR alternator being held on by woodruff key/taper shaft and the zetec is multivee/straight shaft I cannot remember how many.
