mdav1970
Braided Brake Hoses
Hiya,
Wanting front and rear braided brake hoses for my 3a with sierra front and rear brakes.
Thank you guys...
Share this post
Link to post
you might find someone with some but you are probably far better off just getting some made new to the correct length for your car as old ones could be perished inside and/or the wrong length and/or fittings.
don't know any companies myself but hopefully someone will suggest one they've used successfully
hth
Share this post
Link to post
You can buy all the separate bits required from car builder solutions
Been using them for over 10k miles never had a problem and easy to assemble
Share this post
Link to post
Quite a few companies stock the Euroquip brake line parts to assemble your own but I always try and support Car Builder Solutions when possible as their service is great.
Share this post
Link to post
Last time I bought self-assemble style Goodridge fittings, you can get "copy" parts much, much cheaper than genuine Goodridge fittings. I pick mine up locally from a place called Nuneaton Hose & Fittings but I suspect not being local that won't really help with the added postage, you might as well go CBS. A good idea is to look around for local hydraulics shops and "pop in", so many times you can find places that will do you over-the-counter deals for cash. A necessary kit car building skill is most definitely "'ow to 'aggle" :)
Share this post
Link to post
Check out hosetecnik and hel .made to measure and speedy service.
Share this post
Link to post
Always used Hel on my Harley's and Goldwings - excellent!
Share this post
Link to post
