Hello all
My first post so please forgive me if this has been discussed before,
I'm looking for some help with my new build,I've just finished a year long restoration of my s7, it passed it's mot for the first time in over 10 years. I'm running a duratec on standard injectors and a microsquirt ecu, but I'm struggling to find a standard ignition timing map, is anyone on here running a duratec, I'm keen to see an advance table for a standard set up. I'm experiencing some hesitation when cruising and I'd like to eliminate ignition advance as  being the issue.
Any help would be greatly appreciated. Cheers Andy
i have one you can compare but i cant post it here you would have to go to our facebook page  i have uploaded a map
Edited by tractor
Agree that map needs a little tweak.   Some of the numbers are lower then the corresponding numbers.   11 /15 /14 /17.   But dam good as a base to tweak to get someone started.
Thanks again tractor, the car is running much better every time i adjust the maps, and essentially i just want it to run ok until i finish all the shakedown work then ill try and find a local dyno tuning shop and get them to set it right.
