Is the indicator relay the same relay as the hazards?  I have replaced the indicator relay for a led type and indicators are good but hazards don't work.
I need to know if the hazard relay is combined with the indicator relay or are the sperate relays?
I have already replaced the indicator relay with a led adjustable flasher rate relay.  The indicators work fine..... Hazards do mot work.
Hazards and indicators are fed from different fuses, hazards are live all the time and indicators from ignition. I think sometimes the hazard switches gets a bit sticky and need a bit of persuading to work, mine stopped and cycling the switch brought it back.
  • 3 weeks later...
A big thank you to our club secretary Richy "A true gent"
My indicator stalk was causing my hazards issues the circuit board was damaged and its mot time..... Richy came to the rescue who had a spare stalk and posted it to me.  All fitted and everything is working OK.
@apgodden was this a faulty switch  I think im suffering the same with the same code of 90 on the stalk.
Hazards with no ignition working fine.
Right indicator working with hazard pressed down.
Left Indictor is turning the hazards for front and back.
Do you recon the stalk has gone ?
Edited by RickDaley
It is possible.  The issue with mine was the printed circuit board for the hazard contacts were badly worn.  Took me ages to find it.
The only way would. Be to remove the back cover and termove the hazard button.  Be careful to keep the stalk in position. If this comes out it's a bugger to get back......
@apgodden tried your method opened it up looks like the hazard button inside is badly damaged for the latch so it won’t lock into place. Also the contacts on the back of the pins was very oxidised. I managed to get everything back after an hour or so but now I don’t have have the left or right working at all.
I needed up putting a post asking if anyone had a spare stalk with the 90 code that I could buy. Don’t suppose you have a spare one ?
