Have a look through Iva manual and from answers on here, but I think standing as proud as it is it will be Ng but recessed into a foam covered dash will be ok especially if it is behind steering wheel where it has less chance of causing damage to face or body
Thanks Guys
I went through all the usual, google, transit forums, owners manual etc etc and decided easier to stick with my sierra stalk
Thanks to all for the help
Live from fuse box to gauge, other terminal on gauge to sender insulated terminal, sender body should be earthed through tank bolts (ensure tank is earthed to body) and it should work
Hi
My S7 has one piece rubber fuel line from tank up into boot floor, through bulkhead, and runs inside side rail through cockpit and into engine compartment to fuel pump, I have had no probs at all with this set up.
Regards
Harry
Universal choke cable (similar to old mini) off ebay £8.99.... spot on, drilled dash,cable through, nut on back and connected to bike chokes with nipple end... 1/2 hr job
Have you checked the carb for 'jellied petrol in float chamber n jets? happens when petrol stands and it goes off, is the fuel filter partially blocked? have you checked the ignition timing & the valve timing? theres lots to do before you go for rolling road session
Had a look at it today, looks like I've dislodged dip stick tube when I've been fitting starter motor and new starter circuit wiring and the oil looks as though its been coming from there
