MarkBzero
Everything posted by MarkBzero
  1. MarkBzero
    Clutch Cable
    Thanks Nigel, Good find. Perfect going to order one better then playing around with a pinch bolt at the pdeal end. Regards Mark
  2. Chris is right I had one on my high spec sierra (African import) loom you will not use it so cut it off. It included a bulb failure device, low brake pads, low coolant and low washer lights etc. If I remember I had to re-join an earth cable and one other so please remove one wire at a time. Regards Mark
  3. Best of luck hopefully first time pass.
  4. Paul, Thank you, appreciated. Regards Mark
  5. I am going to fit twin 40's if you don't mind me asking how much did they charge. Too far for me to travel and would like a rough price to compare locally. Regards Mark
  6. Thank you round lights will be fitted this weekend. Regards Mark
  7. MarkBzero
    Dif Ratio
    Luke, This subject is somewhere on the forum but can't find it, but I downloaded the contents last time please review the information below. Diff Codes ( Ford Sierra Diff codes, Differential Codes, Diff Numbers, Sierra Diff ) Ford axle codes A=3.36 B=3.77 D=3.92 F=3.842 J=4.056 K=3.31 M=3.14 N=4.29 P=3.58 J=3.62 V=3.33 Z=3.59 2=4.27 3=3.62 4=3.82 5=3.26 6=3.12 8=3.56 3,14 CW47-Pin15 3,38 CW44-Pin13 3,62 CW47-Pin13 3,92 CW51-Pin13 3,77 CW49-Pin13 6.5 inch diff 3,38 fitted to 1,6 OHC ECO 5 speed 3,38 fitted to 2,0 OHC HC 3,38 fitted to 2.3 v6 ESTATE 3,14 fitted to 1,6 OHC ECO 4 speed 3,14 fitted to 2.3 v6 SALOON 3.14 fitted to 2.3 Diesel 85GG 4006 DC --- 3.97 85GG 4006 BC --- 3.62 85GG 4006 AC --- 3.38 85GG 4006 FB --- 3.36 87BG 4006 GB --- 3.14 86GG 4006 AAA --- 3.92 LSD V87BB 4006 BAA --- 3.62 LSD V87BG 4006 CAA --- 3.38 LSD 85GG 4006 AAA --- 3.36 LSD Vin plate codes for Diff ratio Ratio Code 3.14 M 3.36 A 3.38 V 3.62 U 3.64 3 3.92 D Hope this helps. Regards Mark
  8. Very nice exhaust note to self: speak to Dave when engine is fitted.
  9. MarkBzero
    Fog Light
    Quick question for IVA can the fog light be round to match the other lights or must they be square? Thanks in advance. Regards Mark
  10. MarkBzero
    Wheels
    I could not decide between black or silver wheels then came across these, a bit of both what do you think? Should be off the axle stands this weekend for first time - at last.
  11. MarkBzero
    Getting Closer
    John, Thank you, I'll order tomorrow and hopefully pick up at next show. Cheers
  12. Wheels arriving this week!
  13. Kev, I know about the wifey thing I need to re-do my wedding vows and add a clause about kit cars........ Mark
  14. MarkBzero
    Getting Closer
    John, Looking good, is the boot kit from GBS or have you made it yourself? Regards Mark
  15. MarkBzero
    She Rolls!
    Russell, Looking good, new wheels should be arriving this week then off the axle stands. Best of luck with the rest of the build. Regards Mark
  16. MarkBzero
    Malt Shovel
    Hope to be there this time wife permitting......
  17. MarkBzero
    Zero Pass
    Great build Graham look forward to seeing the car and giving me some inspiration to get back into the garage. Mark
  18. Private land is the safest place. Where I used to live whilst restoring series 1a landrovers we used a business car park on Sunday when they were not trading.
  19. I'm getting interested in this idea, next visit to scrappy's going to look at some alternative dash boards.
  20. MarkBzero
    Iva Pass At Last
    Well done, see you at the show.
  21. MarkBzero
    Parts Catalogue
    Good source of information saved in favourites. Thank you.
  22. Femi, How did it go I am going to fit mine this weekend if my wheels arrive on Saturday? Regards Mark
  23. To help further I would suggest you buy her the B&Q DIY or Readers digest DIY handbook great advice on areas of the home, including security and domestic repairs.
  24. MarkBzero
    Seats
    I agree with Nick's comments at the show's your have a little room to barter and special deals no tradesman wants to return with stock. Regards Mark
  25. MarkBzero
    Build Space
    Plenty of space I am building with 15cm clearance front and rear, and only 80cm to the side. I have to climb over the car to work on one side to the other. I have cursed a lot but it will be worth it biggest problem is jacking the car up and moving it from side to side it wastes a lot of time but still possible and patience......
