April 29, 201511 yr Im looking into buying a Robin Hood but i am slightly worried about the IVA test as this car hasn't got one. After asking about why he never got an IVA on the car he wondered why i was looking into an IVA because if i could get a Sierra v5 Logbook i could get a non Q plate and it will still be road legal and i can get the MOT etc etc. I never heard of this before and as i am new to this im not sure at what to look for to find out Any advise would be appriciated Thanks Jack
April 29, 201511 yr No. If it doesn't say "Robin Hood" on the V5 - walk away. If it still says Sierra or something else, it is not legal. Or is this a part built - unfinished car? If so, then it NEEDS to go through the IVA test. Budget on £1000 to cover this test, possible re-test, first TAX and £55 initial registration fee. All adds up to a good chunk of that £1000 Simon. Edited April 29, 201511 yr by Simon B
April 29, 201511 yr So i can't just get a Sierra v5 regester the car on that and go, i have to get it IVA tested... this is what i thought just wanted to confirm Jack
April 29, 201511 yr Just seen your add on Simon. The car is complete and ready to drive away (if it was legal etc). The guy used it as a track car so its all running but he had no intrest in getting it road legal. He said he has all the papers and photos that i know are usaully needed for the test.
April 29, 201511 yr No, that is called "Ringing" and would get your collar felt. Out of interest, does this vehicle already have a licence plate and V5? If not, then what he is suggesting sounds real dodgy and illegal. Simon.
April 29, 201511 yr no it doesn't already have a plate. I (wrongly) assumed it would have a V5 so i don't know. He did say it has everying from when the car was first bought from the manufacturer.
April 29, 201511 yr Posting just crossed over. If it is not road legal now, then it NEEDS to go through the IVA test and the BUILDER has to declare that HE BUILT IT HIMSELF. So, kind of tricky if you are relying on his photos to prove the build. Also, track cars are usually built DOWN to be light and a lot of the REQUIREMENTS for passing the IVA (e.g sharp edges) are unlikely to be met. Simon.
April 29, 201511 yr Certainly sounds like he is suggesting you buy an identity and use that, which could get you in a lot of trouble.
April 29, 201511 yr In that case, this car will need a LOT of work in order to get it road legal. Maybe even a complete strip down and rebuild. Simon. Edited April 29, 201511 yr by Simon B
April 29, 201511 yr He didnt build it either he bought it like that... By the sounds of things it seems like i need to swiftly walk away from this. I am guessing its much safer and easier to spend a little more and get a car already road legal
April 29, 201511 yr How much is it? Got a link to the advert? It certainly sounds like you should walk away however it is possible to declare it as having partly been built by another amateur builder.
April 29, 201511 yr I agree with theduck above (I tried to edit my post TWICE to add this and both times the forum ignored my edit ... ) Simon.
April 29, 201511 yr It has ended but he is re-listing it http://www.ebay.co.u...=p2047675.l2557 £2800 Edited April 29, 201511 yr by jack11
