Based on the fact that it seems to be the first thing that rusts and it's very obvious, i was considering putting a coat of Hammerite on the central boss of the brake disc (obviously not the braking area) - is that ok to do?
I ask only because no-one ever seems to do this - i saw a brand new 5-series that looked great except for the trace of rust already appearing on the disc boss.
Think you might need some higher temp paint than Hammerite, bit in principle sounds like a good idea. There's quite a few options if you search for high temperature paint on eBay ...... got me thinking now!
I would say a definite NO . The heat generated will be too much to handle.
I've always painted mine with VHT aerosol paint either silver or black but not where the wheel seats. Never had a problem
Ive done mine with hammerite for years.. hate the rusty bell on the disc.. never had any issues.
Hammerite Smooth Black on ours -- no problem 34,000 miles/3.5years -- but we are old & slow.
Slow in typing as well.
Edited by florin metal works
Gloss stove enamel aerosol.
B&Q.
Cheap. Easy to use and blings like No 10 front door.
I've used stuff similar to hammerite before, and it worked ok
As above Hammerite black /silver never a prob temps on the road are unlikely to get to the point where there is a prob, track days may be different , caliper paint may be another route to follow mick :crazy:
Not the braking area, but less obvious - no paint on the area where the wheel touches the disc either.
whys that then....???
Differing paint thickness could cause the wheel not to sit straight and cause vibrations
lots of discs are now coming from the motor factors either lightly painted or zinc plated fitted a set of expensive discs to a range rover sport they were black all over pad area soon went shiny on the test drive.
sprayed mine with a light coat of red oxide for the build ( going to be a while :( )
yes you are right,
works the same way a grinding wheel is mounted.
something to do with the transference of energy.
I'm sure someone will come up with the full scientific/engineering answer.
I've very lightly painted discs on various cars over the years and never had any obvious problems,
if anything I would say that the expansion of rust between the two surfaces would be more of a problem,
how many people have had to use a large hammer to remove old discs I certainly have.
