Sign in to follow this
geordie40
Warm Feet
During this glorious weather we have been having I have had the misfortune to be stuck in some rather slow moving traffic and whilst the car temp does go up not that it over heats but I dont like it creeping up near the red I can manually turn on the radiator fan to help bring temp back down but it doesn't half roast my feet and the same thing will happen if we start moving again.
I thought that the foot wells were sealed or one piece, not the case ?
Basically if I fit side vents into the bonnet will this help to keep engine bay temp down if so any idea where to get some also does wrapping the exhaust manifold in heat tape help?
Any other suggestions appreciated
Share this post
Link to post
You will be grateful for that in the winter :)
Why do you need to manually switch the fan on ? Does it not come on automatically as the engine gets hot ?
Both Andy and I have lagged our exhaust pipes and I have fitted vents either side of my bonnet. https://www.ebay.co.uk/itm/316-Stainless-Steel-Marine-Boat-Yacht-Louver-Vent-8-Slot-Ventilation-Grill-Cover/332422388275?hash=item4d65eb1a33:g:uZAAAOSw-xVZ7Ztl
But it is still like sitting in a sauna. Although to be fair these temperatures we are seeing are pretty abnormal.
Share this post
Link to post
I thought that the foot wells were sealed or one piece............?
They should/can be. That's the way they were designed. It's up to the builder how effectively how well the bulkhead is sealed.
The car produces a lot of hot air under the bonnet. Anything you can do to reduce the production of hot air or assist its escape from under the bonnet will help.
Share this post
Link to post
I fully sealed the bulkhead with expanding foam and metallic trunking tape but my feet still got hot where the 4 branch gets close to the footwell.
My solution was the cover the inside with heat mat and the outside with similar, I wrapped the manifold and the final light bulb moment was to just prop the rear of the bonnet 5mm.
Heat rises and the wide gap lets a lot of heat out.
I then hid the washer jets bellow the bonnet
Share this post
Link to post
Good ideas everyone, like the one about propping rear of bonnet a bit, I have seen the side vents but it scares the s**t out of me to cut my nice titanium bonnet!!
Were the vents easy to fit Alan?
I think the fan does come on by itself Alan but I've never had the car that hot on the driveway to check, maybe after next run out will leave it running when i get home and check, I just flick fan switch when sat in traffic for any length of time
Share this post
Link to post
Wrapping the manifold made a big difference to the under bonnet temperature on my car but beware that heat has to go somewhere so the exhaust will be mega hot, ready to burn the unwary or careless. I used some vents I got off ebay, they are a marine grade stainless steel. Just cut a hole and rivet them in. I have seen them on several other cars and they are available in different sizes. It's easy to get air in through the front of the car as there is a big gap in the nose cone but harder to get it out so any vents or louvres will help.
Share this post
Link to post
The footwells arent very well sealed or insulated on the Superspecs. On my car the centre tunnel area under the dash above the gearbox where the wiring loom hangs, doesnt have any covering, so theres a big hole where the hot under-bonnet air can get into the interior.
As Al says, its great in the winter (no heater needed), but in this hot weather temps in the footwells can become almost unbearable. I can tell when my radiator fan turns on as I get a rush of extra hot air into the footwells!
Share this post
Link to post
As Kevin said, very easy. Just used an angle grinder to cut the hole and then pop riveted them in. But I take your point about the titanium, it wouldn't match.
As Andy said, you should be able to feel the fan come on when an extra 'slug' of hot air comes through, although I have wired in a warning light to let me know. The thermostatic switch for the fan is embedded in the bottom right of the radiator. but mine didn't work so I plumbed a switch into the top hose instead. With the fan running my coolant temperature never goes above the 'O' of 'NORMAL' on the gauge (equates to 87C).
Share this post
Link to post
I Lagged my Exhaust Manifold and it helped keep the HEAT DOWN and it looks "COOL" too .
Share this post
Link to post
Nasty stuff that wrap though. Need to wear gloves, a boiler suit and a face mask really. Makes you itch like mad if it gets on the skin and it doesn't last for ever as it gets very fragile after a few years.
Share this post
Link to post
Thanks all again.
Alan I have a feeling my thermostatic switch may not work hence the builder wiring in a physical switch. On a normal day then mines about the same as yours and when I turn fan on it drops to about where it should be
Share this post
Link to post
OK, don't try removing it as it is held in using a 'Do Not Reuse' washer and you cannot buy them any more. It's almost impossible to make it leak-proof afterwards.
I used one these in my top hose: https://www.carbuildersolutions.com/uk/aluminium-modular-inline-housing-38mm with a 95C thermostatic switch.
Share this post
Link to post
What is the "do not re-use " washer made from Alan?
Share this post
Link to post
Not sure. Plastic of some sort I think. Maybe polyurethane ? As you can see from the picture, apart from the DO NOT RE USE warning there is URP and something else written on it.
Share this post
Link to post
