johnlrichardson
406 -
Everything posted by johnlrichardson
Andi it was Saga insurance. Had the same trouble with AA recovery a few years ago. I had to go through my credit card company to get a response from them. They have promised to refund my money. Before renewal tell them NO AUTOMATIC RENEWAL jon
I've changed to a new insurance company only to find the old one has automaticaly renewed my policy using my credit card details I gave them last year. I would have thought that this was theft or fraud but when the policy was taken out last year (in the small print it gives them the right to renew automaticaly). Because I have accepted last years policy, I have given them the right to take whatever they want from my credit card account which I cannot stop, unless I phone them well before expiry and say I don't want automatic renewal, My credit card company say I have given them permission to take it by accepting last years policy They also say it is causing a lot of trouble as more insurance companies are doing it. The insurance tried to charge me £50 to cancel HTH jon
How To Fit A Rear Crank Seal On A Ford Pinto Without A Tool
johnlrichardson replied to biksz's topic in Mechanics
Use the small end of a cable tie to push the last part of the seal over the end and use lots of oil or grease Do not use a screwdriver or anything sharp as it will cut the seal, dont remove the sump HTH jon -
Hi Pedro I live at the top end of Ashington .You may be able to get an adapter made up from the cable to the speedo. I'll have a look if you give me a ring. I have a 2B. jon (phone 853737)
Dont know about the escort ones.but the cossi sierra ajustable ones are bent at a different angle. HTH jon
Turn engine until the timing mark is on top.d centre.Then see where the rotor arm is facing in relation to the dizzy cap. and make sure that lead goes to No1 plug and the next one to No3 and so on HTH jon
Splines fitted over a round shaft without splines on the steering column (is madness) Any manufacturer doing it should be SHOT And anyone owning a superspec should be checking it
Northeast. Washington Restoration Club Open Day Sun 1St Sept
johnlrichardson replied to johnlrichardson's topic in Events
Mastaforth. Anybody can get in. and in any car. bike. whatever see you there jon ps. field to park in -
Been invited to the above open day. Classics in various stages of rebuild. Smashing workshop and all sorts of tools, very interesting. Anyone interested, see you on the A19 at the layby between Moor Farm roundabout and the Holiday Inn at 10.30am, then 11.00am at Washington Services. Post code=NE38 8QB for anyone making their own way there. Bring picnic jon
If you stick it on. it will be a bugger to get off HTH jon
Make sure it can be read As it will be checked john
If you replaced a 5speed box with another 5 speed, the opposite side to where the cable goes in, is a top hat (dome), remove it. Inside the box is a plastic gear wheel, it will just lift out. Do the same to the new box and swop them I think there are 3 gear wheels, green, blue and black, each has a different number of teeth, which can alter the revs to the speedo. Make sure the top hat is tight and sealed when you refit If you have replaced a 4 with a 5 speed box you may need any one of the three. HTH jon
Just received the Boys in Hoods mag, In the events page, Donington Kit Car Show is listed as Aug 31 & Sep 1. Some people may not use the internet and rely on the mag for information. Dont know how you can tell them of the correct date. jon
Sometimes it can be a tyre causing it to pull one way The tracking should not cause it unless its towed out HTH jon
Be in before 10 00am (may be a small charge) It was off last year because of the weather. We were there the year before with 3 other hoods. Good show. We will meet up with others if interested john
Check the plug or connections just before the distributor. its a 3 pin plug only 2 wires are used HTH jon
Thanks Florin I should have tried that but its back together now. I think the mounting is angle iron across the chassis with a short piece bolted together to form a channel. and not a square tube like the other mountings. Which may be flexing.I thought I read ages ago somone else had this trouble jon
Drivers side rear bushes on the top w/bone have had to be changed twice in 12months. I think its the mounting at fault. but the other side of the car is ok. Has anyone else had this problem and cured it. jon
Cut the bolts so no thread is sticking through.and put copper slip on the threads when refitting HTH jon
Kit car and Complete Kit car magazines from 2002, free. There may be an odd one missing just need picking up (5 boxes) I'm 17miles north of Newcastle upon Tyne jon
This is the link you need http://www.rhocar.or...showtopic=34650 You can get surreys slightly bigger if you need it. jon
Check this site page 2 It has 2b wet weather gear fitting and further down the page is New surrey top You can get bigger surreys than this one HTH jon
Have you looked at a surrey for the roof instead of full weather gear I'll try and find a manufacturer jon
