Guest Pthomas
Hi All,
Uncertain and inexperienced new member asking for a quick bit of advice please!
I have agreed to purchase this secondhand GBS Zero - please see expired eBay listing:
https://www.ebay.co.uk/itm/122578482611
I've just checked on the DVLA website, however, as its registered as a Robin Hood. Questions:
- Is this is genuine GBS Zero? Is there a way of checking or can you tell from the photos?
- Assuming it is, does the slightly incorrect registration cause any issue/ concern?
- Any other thoughts welcome!
Due to exchange on Saturday so apologies to ask for a quick response...
Many thanks all.
Pete
being a 2009 that would make it an early zero so may be that they were still trading under the robin hood name at that point contacting GBS about it may shed some light
from the pictures it looks like a zero the only downside to the v5 saying robin hood is that it may devalue it in some peoples mind cos it is technicaly not correct
Edited by tractor
Guest Pthomas
Many thanks all. V5 doesn't state a model but I've spoken to seller and has paperwork from GBS regarding the purchase of a "Robin Hood Zero Kit". Also apparently chassis number has 'GBSZero' somewhere in it. So I was just being overly cautious.
Really and genuinely appreciate the quick feedback so thank you!
Pete
Seen this one in the flesh and looks ok can't vouch for it as don't know the guy and not seen it running. As will all custom cars there will be bit you will want to change/upgrade but that's part of the fun!
That actually doesn't mean anything - as a builder, you can make up any chassis number you like and as long as it is unique, the DVSA/DVLA will accept it.I was tempted to put 'FERRARI' in mine ... 8)
However, looks like a good build otherwise, so no problems.
