Zetec Turbo Parts What You Using?
  • Replies 43
  • Views 8.7k
Most Popular Posts
  • You turbo lot are all torque....
  • But I thought the super charger was the mutts nuts Dan
  • speedtripledan
    speedtripledan
    Want a project so thought a turbo sounds like a fun simple thing to try and yes the whining is an issue with the dB meters at the track, won't get through on the stricter tracks
Posted Images
Don't know what you mean rich . Other than sweating power and things coming loose been pretty reliable. As Chris said I made 256bhp don't know torque level as it wasn't on the graph but pulls really well and power all the way to the limiter which is 6800 on mine
Just to add I'm currently running in low boost as don't have a boost controller so only 8-9psi
No comment from me, to much hot air and Torque
If your running 256 at 8 to 9psi then 270 ISH should be achieved at 12psi which is still safe on a zetec. Just need to get the bits now
It was mapped with a boost controller so that would be with higher boost (12psi) but don't own one at the min so only running 8-9 psi so more 200-210. The engines we use should be safe upto 320 ish bhp from what people have done before but on a silvertop I'm not sure what's classed as safe
Been in contact via email with boost performance can't say i.m impressed with there responce to my questions probably going to look else where I need the turbo mounting low down basically where my 4 in to 1 joins together. (Clearance issues) probably going to need a custom manifold making.
Just a suggestion - from my experience some places don't take email contact very seriously, I always try to ring first, have a chat, go over the idea, and then follow up the detail in an email if they ask for it. Builds up some conversation so that they take you seriously versus just another "internet hero with great plans in his head but no intention of actually following through when it comes to committing"....
My turbo manifold bring mine right low down its off a rs turbo I believe
Did try ringing several times with no answer, cheers Dean will look into it
just ordered my performance boost manifold from them through ebay and just messaged them to make it a top entry for turbo
Dean didnt mention that he had to weld an adapter plate to the rs manifold to get it to fit the zetec
its a tidy design
Edited by tractor
