Get a length of wire put a 12v bulb in the middle connect one end to alt and the other end to +12 on battery. Start car if light goes out - wiring prob if it don't then it's a alt problem
Hi selling my 2.0 Zetec ford EEc with complete engine wiring loom
this will enable anyone to run a zetec on full ford engine management
i picked up the bits a few weeks ago just to see if i could do it (bored) -and its surprising easy!!!
this will run the sparks and injection inc fuel pump and tacho drive etc as if it was in a focus and mondao as ford intended
i also have a sheet i made up showing which wires (Colours) do what
you will need a couple of other bits -airflow meter etc to complete the install
looking around £150 posted
please ask if you have any questions
blue
I also run all my earths into batches eg front of car say lights and indicators to one point then use a stainless set screw and nut with a cable large enough to handle the power back straight to the battery.
Hi everyone I'm trying to wire my black top on the ford original ecu ( cos I'm bored !)
Now on the injections there is a small loom that does the 4 injections now the loom is tagged BE
And I have 2 plugs I can't figure out. I have the four injectors the throttle the water temp and cam sensor
But there's 2 plugs one has 2 wires and the other has 1. These two connections are taped together if some one can help on any of this I would be truly grateful.
Indeed if someone has a early mondao and can tell me what plugs and wire colours are on the plugs on the engine sensors even better
TA
i keep the doors on to stop the wind and bought a length of the large gray pipe lagging at B and Q and roll the roof around it and bungie it on spare wheel
you can see how it looks on issue before last of boys in hoods (yippie BEV made front cover)
Hi all thanks for the replys. I'm now looking for practical performance magazine - November 2013 issue ??
Or someone to let me have copy's of the zetec article !
Hi. I'm running the GBS plemum and asking how many of you run with the fuel reg connected on this plemum
I know most of you run emerald and I run webber alpha but my reg is connected and after connecting a vac gauge the vac in the intake is nearly off the scale at idle and at the idle mark on the gauge while cruising - the pressure in the rail must be at least 20psi lower then designed by ford to keep the spray pattern clean.
I know we can map to get a good AFR etc but was purely wondering about what others are doing
Yep late present - £620 plus the dreaded ! Long first gear and close ratio on 1,2,3,4 standard 5th heavy duty bearings etc.
I did look at having mine rebuilt but it was coming out at more after I got the long first gear fitted then I could buy this for ??
now just got to fit it.
Hi my one ive put through the panel - you can buy thermo sleves that the cable runs through but i doubt you would be able to attach it to the manifold for neatness without it affecting the sensor readings even if purley to the extremly radiant heat
Hi all I know this has been covered loads of times but I cant find a simple answer
Looking at back of engine at stat housing am I right in saying
Large hose on left - top rad
Small hose on left heater feed
Very small hose on top - expansion tank
Small hose on right - bypass to bottom hose and heater return
Ha ha every time I go out in my S7 I hear something bounce around the bottom of the car and wonder is it a stone or has something now fell off. - it's all part of running a kit car.
It's why lotus got such a bad rep. The people that bought them thought that they were as good as production cars so never checked them and wondered why bits fell off!!!
Can I ask has your astra got air con.
If so check the last fuse on the right hand side of fuse box where your right knee is when sitting in the car.
If this is blown you get a low coolant warning light even though most bottles never had the sensor fitted.
Pls let me know your findings
