Grim
Area Secretary
Everything posted by Grim
  1. Grim
    Pinto Alternator
    what sort of deflection can you get in the belt, when moving it with your fingers?
  2. I'd be more worried about them applying an emissions update and strangling the performance and increasing fuel consumption. Anyone know what the update is yet?
  3. sure he didn't say 1988? ie when the donor was made? if so that would tie in. If the big points are covered, ie the v5 says it's a robin hood, then i wouldn't worry overly, it's probably a dvla typo.
  4. So, i thought i'd post an update to this thread, as there's nothing more annoying when trying to search for solutions to problems, and finding more questions! I checked over the oil control solenoid and cam sensor wiring, and all proved ok. No crap or such like in the solenoids. Decided to bite the bullet and buy the locking kit (£50) a cam belt kit (£50), vvt pulley (£70) and bolt (£2.50). The car was overdue a cam belt anyway, and changing the vct pulley at the same time was only an hour's extra work. However the job took me 16 hours in total over 1 afternoon and 4 evenings as i had to remove pretty much everything that wasn't the engine from the engine bay. Cleared the fault code (P000A), test drive went badly, reconnected the vct solenoid, cleared new code, and it's sorted. Did a few more jobs, including a new driveshaft and coil, now it just needs an MOT by the end of the month! Andy
  5. The south yorksish meet for October will be at: Red Lion Inn, Todwick, South Yorkshire Usual time of 7:30 on weds the 7th Andy
  6. same earth?
  7. less fuel is just less throttle in a diesel, there must be more to it, like only running egrs in test mode etc. I'd love to know the details!
  8. it's a late model 2b wishbone chassis with cobra hoops. not sure what years they offered the cobra hoops, but someone will!
  9. Grim
    Iva.. Again
    gearstick will need to move up(?) on its pivot, just tap gently until you've got a gate on reverse again
  10. Grim
    2B Rear Suspension
    i think the standard ones took off 2.5° of camber, which i thought too much. I think peter bell made me some for 1.5°, which did the job.
  11. Grim
    Pinto Rebuild Help
    Coolant feed for heater. Route to heater if fitted, or to same sized fitting on the water pump if no heater. Don't block off as it allows water circulation whilst the engine is warming up, and should prevent hot spots. fuel pipe feed connects to fuel rail (opposite end to the regulator), and a return line to the tank from the regulator.
  12. Grim
    Bolts
    if there's movement between flanges, the bolts aren't tight enough. Fully threaded screws should be fine in this situation. If you need to rely on a bolt shank to stop movement of the flange, you have a greater issue. You will still get failure of the bolts by fatigue, sooner or later.
  13. Grim
    Rear Diff
    I wouldn't, 3.6 or 3.9 are best unless you have a torque monster.
  14. Grim
    Trouble Again
    Don't use any if it doesn't leak, it's an electrical connection as it earths through the block!
  15. that doesn't sound... conventional! is the nylon running on the shank of the bolt, not the threaded section?
  16. I tried to resist commenting, but sometimes I can't help myself I saw that thread, but saw no evidence for a HAZ related issue. Possible mechanisms for a HAZ related failure could be "cold cracking" where the HAZ gets heat treated by the welding process and forms very hard martensite. This can lead to cracking, generally quite quickly after welding, so i'd suspect a failure soon after it was made. Only happens with certain types of alloyed and carbon steels, not the steel i'd expect it was made from. Alternatively, the tube could be heavily cold drawn (cold worked), and the welding process softens it around the weld. If the stresses were high enough in normal use, it could then fail by fatigue, but I feel it unlikely as the actual strength loss by annealing in the HAZ would be small in a mild steel. There has obviously not been any testing to prove this, and I don't suspect many people would let me chop up their wishbones! The wishbone has a huge stress concentration factor at the weld, due to the shape of it. The failure will almost always occur at the weld, but that does not mean the weld is at fault per se. I'd go along with fatigue failure due to excessive stiffness / misalignment of the bush / crush tube too short etc, unless there's any evidence to show otherwise. Andy
  17. i don't know what size yours are but if these fit i can reccommend: http://www.wisbechengineering.com/shop/4576331221/urethane-bushes-qty-1-50/6179004
  18. well, i don't want to be swimming around in circles do I?
  19. got two yellow armbands through (for 2 people), and a letter saying i've paid for one day, despite paying for two. Any help?
  20. Why are you earthing to the rev counter? Does that connect to the chassis via another earth point? Your description sounds like you are connecting both 12v and 10v to the gauge. Ignore the +12v to the gauge, that's only for the light. Connect +10v output of stabiliser to the gauge, and gauge to sender. Andy
  21. The south yorksish meet for September will be at: Red Lion Inn, Todwick, South Yorkshire Usual time of 7:30 on weds the 2nd Andy
  22. the stainless panels are a pig to bend neatly, most turn out worse than that. That's what carpet is for, or replace with aluminium.
  23. Phil you should have myself and Clare down, i hope i did it right
  24. There's some terminology misuse in this thread. 23 spline, 18 or 19 tooth gears Andy
  25. i have a dismantleable gauze filter on the inlet side, so little restriction and catches the big bits that kill pumps. Prior to fitting, i caught a piece of debris that had been floating about from the manufacture of the tank, 10 years earlier! Shortly after fitting, the filter caught another bit.
