Start engine, stick foot on brake and move shifter slowly from Park, through each of the transmission positions (pause in each position for 5 to 10 secs). This should purge the transmission and torque converter of air. Stick back in Park and check level with the engine idling.
I agree with Bob. Check the length of the harness for damage. Maybe it's pulled tight now it's clipped in place and has chaffed on a raw metal edge.
Did you put edging around the end of the tunnel near the diff?
A mid week car meet that starts at 4 and finishes at 9, is this aimed at Rover drivers who need to get home to hang up their tartan cap and have a cocoa before bedtime?
With the benefit of hindsight, I'd have left the thermal wrap of the manifold and put it round the bottom of my right leg. Definitely more benefit there.
I used the Clint Eastwood method for mounting my mirrors.
Hang 'em High
You've got a better chance of seeing over and around your rear arches if your mirrors are mounted higher up. IVA tester used all the cones and poles and I passed no problem.
As above, I'm after a pair of 108mm Lobro driveshafts. Ideally I'd also like the hubs, calipers etc. so I can convert to discs at the same time. Shafts need to be 108mm not 100mm to fit the LSD I've already got.
Thanks.
The sad thing is that these smaller factors can't compete with the likes of ECP and GSF and many are now closing. Would much rather be served by someone who's worked in the trade and who can offer advice, not just hand over bits and take the money.
Must be a sign of old age!!
Rover 800 bonnet strut had a mechanical lock built in. Open bonnet fully, then it drops down an inch onto the lock. If you pull down on the bonnet it won't close.
To shut the bonnet, raise it slightly to disengage the lock, then pull down as normal.
Second hand struts will work even with reduced gas pressure.
I've been made aware of this event by Mike Lynock (and it's very local to me). The school are asking for potential themes and he has suggested a turn out of cars that's guaranteed to generate some interest and help raise funds.
The event is planned to run from 1PM to 4PM and Mike should have more details if you contact him via pm.
http://www.rhocar.or...omMemberID=3222
or email mikelynockt@yahoo.co.uk
As more information becomes available we'll add it here.
The school is here:
Wilnecote High School,
Tinkers Green Road,
Wilnecote,
Tamworth,
Staffordshire,
B77 5LF
https://maps.google....=classic&dg=brw
Had hoped to come along but phoned a mate for a quick chat and 90 mins later I had a worn out ear. It's more time than I normally spend on the phone in a year.
Next Wednesday, 25th March , 7pm onwards, Malt Shovel Pub, Coventry Road, Nr Stonebridge, Coventry, CV7 7HL
See you there!
