Area Secretary
Everything posted by Andi
  1. Andi
    Fan Override
    Mmm Think i`d better go from the relay when i suss what wire does what Thanks all
  2. Andi
    Fan Override
    Yes Geoff, Could I not run a live from the fan to the battery via the dash switch which would cut the fan on and off? Electrickery.............. The devils own
  3. Andi
    Evo World Record
    1, Jabberwocky 2, Fozzy2007 3. Andi
  4. Andi
    Fan Override
    I would like the simplest way of fitting a fan override switch in my dash so I can switch the fan on when i need to. I have a three post toggle switch, 25amp cable with inline fuse junction. Thanks
  5. "21" Wacom Cintiq a run" As tablets go that`d be like a Rolls Hood Royce
  6. If you get the pump from the bike it should work perfect, otherwise a fuel regulater with no more than 3psi would be good.
  7. Andi
    Ron Champion
    Sorry guys the link is down Regards Andi
  8. Im thinking firstbuild tried to put up a picture and it didnt work??
  9. Andi
    Photos
    I agree, I was looking at the recent post on tyres and would like to fatten out the back 2. Got yokohamas on but cant remember what size. (Not with the car at the mo) Ill go to the local boy racer tyre man tomorrow for a quote.
  10. Andi
    Photos
    Have to hang my head in shame and say I purchased the car ready built so not sure where it came from and there are no visible markings on it. It is perspex and could possibly be home made as bending/heating this material is not too difficult. Where`s every onel elses pics????
  11. Andi
    Photos
    One of the only nice days this year
  12. Andi
    Mot
    R and R in Wigston as you had yours done there. Ok so he might not be au fait with sliding pillars but not many people are. However he did do a £5 discount as he likes kits, didnt try forcing an emission test out of me and seems a good chap.
  13. Andi
    Mot
    IT PASSED????? I had resigned myself to opting for the expensive wishbones conversion, but just for my own piece of mind wanted to have a final look at the suspension failiure. The bolts all seemed tight but I decided to use brute force and squeeze another 1-2 turns on the bolts underneath the pillar, the pinch bolts and the welded bracket. Took it back to the garage and asked him to shake the car on the ramps again as I couldnt see any movement. Lo and behold no movement and he gave me a pass. Phew! Ill put off the wishbones till the other side of Xmas.
  14. Andi
    Mot
    The tops are slotted and couldnt see any slots on the bottom but will check again. The spring assembly that is coming away has always had problems with grease/oil gathering around the bottom of the bump stop whereas the other "ball joint" side was always clear.
  15. Andi
    Mot
    Second look at the bracket, it doesnt appear to me that it was ever joined up to the pillar as it seems to be part of the wheel hub itself. However up on the mot ramps when the guy shook the car sideways with that clever thingy on the ramps the whole wheel moved outwards. What could be wrong? The article by Chenzo http://community.rhocar.org/index.php?show...&hl=sliding shows his brackets sheared off but mine are fine.
  16. Andi
    Mot
    Just spoke to kit car parts and they say its a cortina joint so one is on its way.
  17. Andi
    Mot
    Just failed the MOT on sliding pillocks. Bottom ball joint nearside gone, anybody know where I can get one from????? Also any local recommended welders who could weld a strut back together on the drivers side pillock. Ill put some Photos up in a bit when me and the car have cooled down.
  18. And your parts wouldnt need to be "hood verified genuine article"
  19. No, just klik on the download button above and to the left
  20. Andi
    Throttle Cable
    https://www.burtonpower.com/product_main.aspx?home.aspx. Thats if you can wait for delivery time
  21. Andi
    2l Pinto Tappets
    Theres a lot of data here http://www.kentcams.com/Downloads/Files/Ke...sBrochure07.pdf
  22. Andi
    Nos
    In their Hood http://cgi.ebay.co.uk/Nitrous-Oxide-Wet-Ki...1742.m153.l1262 Could it really give an extra 150BHP without damaging the car?
  23. Andi
    Plane Collision
    Very very tragic. Had no idea that a plane/micro could be legally home built http://uk.news.yahoo.com/pressass/20080818...ne-6323e80.html
  24. Would be fun and chaos going down this single track tunnel http://images.google.co.uk/imgres?imgurl=h...ficial%26sa%3DG
  25. Yes Yes Yes
