Zetec And Electric Water Pump Still Overcooling
  • Please log in to reply
54 replies to this topic
#1 DanE
DanE
    Electrickery master
  • Community user
  • PipPipPipPipPip
  • 6,472 posts
  • Car type:SSC Stylus Supercharged
Posted 13 September 2017 - 05:33 PM
new Spec 2.0L zetec with 243bhp
         55mm coolex polo derived rad
         raceline water rail
         davis craig ewp 115 electric pump and controller
old spec as above except standard zetec mechanical pump and 82deg thermostat
In the old spec the car would take for ever to warm up to the 82deg sat on the drive idling, if you pulled away before getting to temp it could take 15miles to get to 80 and if you were on a long steady run the temp would drop to just below 80deg, i want it to be 85deg. getting stats to fit, in the right temp is getting awkard as they are old ford xflow fitment so i thought i would try something different
i have now fitted the new ewp pump and controller, and the problem is worse!! the cars warms up at idle a lot quicker, it sits there holding temp perfectly with the fan and pump doing what they should.
I go for a drive and boom the temp drops from 90 to 75 and will not raise until i stop driving then it creeps up to set point and maintains it.
This car used to have an old polo type rad which used to maintain the temps just but was always marginal when you started to raise the pace it would heat up and barely keep things cool, hence the change to the coolex 55mm,
Does the rad have to large a volume and too large a surface area? every time the pump pulses, is it shooting a large volume of cold water round the system which is to much for the engine heat produced?
Is the pump sending to much water round the system? both mech and elec pump did the same effectively. only difference is the mech had a stat the elec dosent its meant to be controlled electronically.
Is the raceline water rail causing some sort of issue?
Is the fact that car has so much torque and power now that i,m not driving it hard enough to generate enough heat?
both coolex and davis craig recommended the rad size and pump to suit the car and its engine spec.
Not sure what to do now any ideas and opinions please
Ssc stylus with a supercharged zetec 242bhp and 253ft lb of wheel spin.
#2 theduck
theduck
    Club Secretary
  • Committee
  • 3,210 posts
  • Car type:Sierra S7
Posted 13 September 2017 - 05:46 PM
Have you tried blocking off part of the rad?
#3 nicko
nicko
    Wheely good builder!
  • Community user
  • 1,281 posts
  • Car type:2B Plus, 2.0i
Posted 13 September 2017 - 05:50 PM
Just a thought... have you tried covering part of the rad to see if that helps? If so then the rad could be too good.
Nick
2.0i 2B Plus. Collected 30/10/04, SVA passed 24/05/07, GRIN factor...... off the scale
Posted ImagePosted Image
#4 mower man
mower man
    mowerman
  • RHOCaR 18
  • 4,120 posts
  • Car type:1992 Mazda mx 5 1600
Posted 13 September 2017 - 05:51 PM
As above gaffer tape the rad in small increments, had to do this on a friends Formula Ford for winter meetings
Edited by mower man, 13 September 2017 - 05:52 PM.
MOWER MAN the older I get the faster I was ! but getting faster after having my knees refurbished
#5 DanE
DanE
    Electrickery master
  • Community user
  • PipPipPipPipPip
  • 6,472 posts
Posted 13 September 2017 - 05:52 PM
Yes it did help a little bit. But it still wouldn't maintain set point
Edited by DanE, 13 September 2017 - 05:52 PM.
#6 cb750
cb750
  • RHOCaR 18
  • 1,176 posts
  • Car type:3A
Posted 13 September 2017 - 05:55 PM
Have you tried contacting Davis Craig and asked them if they have come across this before?
#7 DanE
DanE
    Electrickery master
  • Community user
  • PipPipPipPipPip
  • 6,472 posts
Posted 13 September 2017 - 06:01 PM
Yes I've emailed them, not ringing as they are in Australia. Awaiting a response
Also spoke to coolex who haven't come across the issue and find it very strange!
Edited by DanE, 13 September 2017 - 06:02 PM.
#8 richyb66
richyb66
  • Area Secretary
  • 1,880 posts
  • Car type:2B wishbone 4.6 V8
Posted 13 September 2017 - 06:05 PM
7 days
Oh no, that's Craig David
Warks, Worcs, W Mids area meet. Last Wednesday of the month 7PM onwards, January to November. Malt Shovel Pub, Coventry Road, Nr Stonebridge, Coventry, CV7 7HL
#9 kevin the chicken
kevin the chicken
  • RHOCaR 18
  • 816 posts
  • Car type:16v vauxhall series 7, Sylva Leader with Pinto
Posted 13 September 2017 - 06:38 PM
Are you 100 per cent sure the gauge is accurate? If the stat or the electronic gizmo aren't giving the correct temperature it seems a bit strange. Surely one of them should work properly. They should control the engine temperature and compensate for over cooling by closing off the flow. Or that's what I thought anyway. Years ago loads of people would blank off parts of their radiators in the winter.
#10 DanE
DanE
    Electrickery master
  • Community user
  • PipPipPipPipPip
  • 6,472 posts
Posted 13 September 2017 - 06:54 PM
3 temp sensors all reading the same, pump controller, gauge and ecu
#11 Longboarder
Longboarder
    Old Stager
  • Community user
  • PipPipPipPipPip
  • 7,995 posts
  • Car type:New 111
Posted 13 September 2017 - 07:38 PM
Have you removed the old mechanical pump? If its still in circuit it will have an effect.
Can you do a diagram of the cooling circuit please. Include all parts, pipes etc.
Thought for the week.
Forget healthfoods. I need all the preservatives I can get.
#12 DanE
DanE
    Electrickery master
  • Community user
  • PipPipPipPipPip
  • 6,472 posts
Posted 13 September 2017 - 08:06 PM
Plumbing is bottom rad outlet to electric pump inlet, pump outlet feeds into mechanical pump (impeller removed) that then exits head to race line rail which in turn feeds out to top rad inlet. No stat
#13 Longboarder
Longboarder
    Old Stager
  • Community user
  • PipPipPipPipPip
  • 7,995 posts
  • Car type:New 111
Posted 13 September 2017 - 08:27 PM
I'm guessing the sensor for the pump is in the rail close as poss to the outlet on the back of the head?
#14 DanE
DanE
    Electrickery master
  • Community user
  • PipPipPipPipPip
  • 6,472 posts
Posted 13 September 2017 - 08:44 PM
No pump sensor is in top hose, gauge and ecu are by the head, but they all read similar
#15 theduck
theduck
    Club Secretary
  • Committee
  • 3,210 posts
Posted 13 September 2017 - 09:39 PM
Just a thought, have you got an oil cooler fitted?
