All Activity
This stream auto-updates
  1. Today
  2. Yesterday
  3. We don't want to waste this glorious driving weather so the East of Englan team were out and about again today. We went to Sywell Airfield, which has the advantage of a large car park and a great view over the airfield while having a picnic. It's also a good run for alll of us with journey times between 40 mins and 1:20 hrs. We parked in our usual place in front of 2 other classics (a Hunter and a Jetsream for non-aircraft spotters) and watched all the activity, inclusing 2 spitfires and a Mustang giving joy rides, a microlight and lots of small aircaft. Great day. Not as windy as it looks, those trees have grown like that
  4. I've been offered an ST170 engine with throttle bodies and their loom. The seller doesn't have the ECU, he has no other loom pieces so no ECU connector, no ignition barrel, no keys and no Dash Cluster. So my question is as a bare minimum what do I need to have to get it to run ? Not looking to spend a fortune at this stage, the seller bought it as a runner but of course he'd say that Thanks, Karl.
  5. Of course we care, but we also have to be realistic. We have a limited amount of space on our host server and at present we are already hosting 20,576 pictures dating back to 2003, so we have to limit the size for each post and image. So all we ask is that you are sensible. If you pre-shrink your picture to a reasonable size to display then you can post more pictures without any change in the display. For example a raw picture from my iPhone is 4000 px by 2000 px. The maximum we allow is 1200 px by 1200 px so you cannot post it as it stands. But if I shrink it to 20% it is only 800 px by 400px yet still displays perfectly on the screen. We also limit the overall size of the post, and unfortunately as you are not a member you will be severely limited as to the number of pictures you can post as well. Members have a much more generous allowance and can post almost as many as they like. There are many free programs available to do this shrinking (technically called ‘resizing’) operation, personally I use paint.net. Hope that helps. Al (Webmaster)
  6. I can see why this forum is declining. Sorry to ask, but did the originator of this forum pass on? I'm way over the Atlantic with this Robinhood car, sure draws attention at the right locations. I'm planning to get as many stickers along historic Route 66 and stickerbomb under the trunk lid. Am I limited on website space, and need to share via a photo-hosting site? If anyone cares?
  7. Last week
  8. Only just long enough, but they have held for 17 years.
  9. I think its an escort rack mk2? On mine there's a good bit of thread visible, it's been fine for years.
  10. Not surprised. And it will not come back.
  11. June was not good. We lost 10 members and only had 5 new members join us. So we welcome: Username Location Area Secretary Mitch1991 Chesterfield Andi Matt82 Sheffield Grim WillB Thatcham ThanasisPolitis mmarksx19 (Michael) Leeds Grim Ax2020 (Luca) Italy/Spain to the Club
  12. Doesn't matter now, Newark/Lincoln has been Cancelled "It is with great regret that we announce that the Lincoln Kit Car Show has been cancelled. We had hoped that the move from Newark to Lincoln would have been a good one for the show but unfortunately there has not been enough interest from trade to justify running the show."
  13. Listing has now gone live on eBay, lower opening bid
  14. The only issue I can think of is if you are looking to get an age related registration number. You would then need to show proof of the minimum number of parts from the original donor vehicle, or alternatively you would need to provide proof of the minimum number of new parts for a new reg number. Either way I don't imagine an LSD will make any difference to the IVA test ............................ however, somebody may know otherwise
  15. Raising the seat height wont be an issue. Currently the seat is bolted to a frame which is 20mm off the floor and the frame is bolted to cross members in the chassis that are pre drilled, hence the specific dimensions. By using runners, the seat frame wont be used so the difference will be minimal if at all. The car is a MEV TR1ke Mike
  16. One thing to think about is that seat runners will raise your seat about 1 inch. It does not sound much but put some packing on the seat and evaluate the view through the windscreen, where is the top rail? The screen can be raised but any hood will then also need adjusting. As someone the looks out through the top of the windscreen I am aware of it when driving. I have run out of adjustment. Also what car do you have as that can change advice.
  17. Hi all, Just got my new toy and starting to fiddle with it to make it just how I want it. The car has GRP seats and they are a little too far back for me. I would like to use adjustable runners/sliders whatever they are called! Currently, the seat is bolted to a frame through the seat base which is bolted to the floor. I'd rather not drill the floor so looking for a solution to use the existing mountings on the floor pan. I have no ability to weld or fabricate but can turn a ratchet from a socket set with some success!!!!! The holes in the floor pan are 275mm side to side and 330mm apart longways. I think, from what ive read im better off with a twin locking system rather than single sided as its more secure. Does anyone know of a suitable product I can install that would work with these dimensions? I've seen a lot of seat runners that state a maximum length of 310mm. Is that the plate or the amount of adjustment???? I hope there is a product out there that I can simply bolt into the existing holes and then bolt my seat to it. I look forward to your product suggestions and expertise.
  18. Can, or perhaps should I install a LSD before IVA? I am looking at a quaife ATB kit for my open Sierra 7" diff and would prefer to build in from start if possible. Is it allowed and are there any cons?
  19. Thank you Foz! Yes really fun to drive! Even if overtaking with RH drive in a LH country Is a bit challenging some times and this Monday I will start with changing the fuel pump and playing with the carbs a bit. After that probably the cooling system, but step by step the summer is started and I want to drive it a bit more, also I need to learn a few things before starting to works on it
  20. Had confirmatio from the organisers that we have a nice discrete club stand next to the castle but near the back (Square 46 on the site map). All the relevant details are in the attached PDF file. Any questions let me know. Kimbolton 2025.pdf
  21. Congratulations on getting it sorted. Now it's welcome to the world of kit cars where there is always something that needs doing, or something you want to change on the car, but always fun to drive it
  22. Earlier
  23. Well done on getting it on the road.
  24. Finally, after almost a year of burocracy between the department for transport and the historic cars registry, I'm the owner of the Robin hood 2b of my previous post. Now I need to start working on it, I used it this week almost as a daily driver. But it need some works, it's running quite hot and the carbs need some tuning, but I'm happy to finally be able to drive it
  25. Just got a pass out so we are in fighting distance.
  26. Andi, we got five cars at the West mids meet tonight let's see if Staffs can do better.
  27. Not a bad turnout tonight, better than Malvern!. Let's see if Staffs can do better tomorrow.
  28. Hi Mike, message sent
  29. Hi, really interested in this but not sure how to message you (I only signed up to the website this evening). Can you message me so I can reply or email me at mmarksx19@gmail.com? Many thanks, Mike
  1. Load more activity
