All Activity
This stream auto-updates
  1. Past hour
  2. Yesterday
  3. Listing has now gone live on eBay, lower opening bid
  4. The only issue I can think of is if you are looking to get an age related registration number. You would then need to show proof of the minimum number of parts from the original donor vehicle, or alternatively you would need to provide proof of the minimum number of new parts for a new reg number. Either way I don't imagine an LSD will make any difference to the IVA test ............................ however, somebody may know otherwise
  5. Raising the seat height wont be an issue. Currently the seat is bolted to a frame which is 20mm off the floor and the frame is bolted to cross members in the chassis that are pre drilled, hence the specific dimensions. By using runners, the seat frame wont be used so the difference will be minimal if at all. The car is a MEV TR1ke Mike
  6. Last week
  7. One thing to think about is that seat runners will raise your seat about 1 inch. It does not sound much but put some packing on the seat and evaluate the view through the windscreen, where is the top rail? The screen can be raised but any hood will then also need adjusting. As someone the looks out through the top of the windscreen I am aware of it when driving. I have run out of adjustment. Also what car do you have as that can change advice.
  8. Hi all, Just got my new toy and starting to fiddle with it to make it just how I want it. The car has GRP seats and they are a little too far back for me. I would like to use adjustable runners/sliders whatever they are called! Currently, the seat is bolted to a frame through the seat base which is bolted to the floor. I'd rather not drill the floor so looking for a solution to use the existing mountings on the floor pan. I have no ability to weld or fabricate but can turn a ratchet from a socket set with some success!!!!! The holes in the floor pan are 275mm side to side and 330mm apart longways. I think, from what ive read im better off with a twin locking system rather than single sided as its more secure. Does anyone know of a suitable product I can install that would work with these dimensions? I've seen a lot of seat runners that state a maximum length of 310mm. Is that the plate or the amount of adjustment???? I hope there is a product out there that I can simply bolt into the existing holes and then bolt my seat to it. I look forward to your product suggestions and expertise.
  9. Can, or perhaps should I install a LSD before IVA? I am looking at a quaife ATB kit for my open Sierra 7" diff and would prefer to build in from start if possible. Is it allowed and are there any cons?
  10. Thank you Foz! Yes really fun to drive! Even if overtaking with RH drive in a LH country Is a bit challenging some times and this Monday I will start with changing the fuel pump and playing with the carbs a bit. After that probably the cooling system, but step by step the summer is started and I want to drive it a bit more, also I need to learn a few things before starting to works on it
  11. Had confirmatio from the organisers that we have a nice discrete club stand next to the castle but near the back (Square 46 on the site map). All the relevant details are in the attached PDF file. Any questions let me know. Kimbolton 2025.pdf
  12. Congratulations on getting it sorted. Now it's welcome to the world of kit cars where there is always something that needs doing, or something you want to change on the car, but always fun to drive it
  13. Well done on getting it on the road.
  14. Finally, after almost a year of burocracy between the department for transport and the historic cars registry, I'm the owner of the Robin hood 2b of my previous post. Now I need to start working on it, I used it this week almost as a daily driver. But it need some works, it's running quite hot and the carbs need some tuning, but I'm happy to finally be able to drive it
  15. Just got a pass out so we are in fighting distance.
  16. Andi, we got five cars at the West mids meet tonight let's see if Staffs can do better.
  17. Not a bad turnout tonight, better than Malvern!. Let's see if Staffs can do better tomorrow.
  18. Hi Mike, message sent
  19. Hi, really interested in this but not sure how to message you (I only signed up to the website this evening). Can you message me so I can reply or email me at mmarksx19@gmail.com? Many thanks, Mike
  20. A reluctant sale of our Superspec "Britney" Built and owned from new by us, she starts first time every time and is ready to be enjoyed this summer. Unfortunately due to me working long hours and busy weekends she doesn't get used as often as she should be and is mainly polished, run to temp and given a quick run before returning to the garage, so it is time for a new owner to make the most of the good weather! Ready to turn the key and motor through the summer! Just over 3000 Miles MOT valid till October 2025 Registered with one previous owner (passed down in the same family from father to son) Fully road legal Build upgrades and fittings include: Smiths dials. 4 new Kumho tyres. Gaz adjustable shock absorbers all round. Remote oil filter housing. Surrey top roof. 2 side doors and Full wet weather gear (not fitted). USB connection for ECU diagnostics. Trickle charger with SAE quick connector. Folder with all original paperwork including Robin Hood bulletins and technical updates. Haynes manuals- Ford and Rover Recently serviced with: Oil, filter, timing and aux belt change New fuel pump Coolant flush Brake fluid flush and change New rear brake cylinders left and right Please message me for further information or photos Car is based in Ripley, Derbyshire Selling for £5000
  21. I've just looked at the latest weather forecast and it could be warm and dry on Thursday evening - plenty of time for it to change before then though
  22. Earlier
  23. Tony
    Camber wedges
    I am trying to find someone who has camber wedges for sale to suit a 2b . Thanks in advance
  24. Look forward to seeing you
  25. Hi I'll be there hope that the weather stays fine till Tuesday Allan
  26. You're just trying to confuse an old man aren't you - well you succeeded I've booked plot 25 from Friday to Sunday - as ever I'll do my best to be there ........... barring normal disasters I haven't booked my pass out yet so I'll have to let you know about the meal later. Steve
  27. Sorry everyone We have got the wrong dates. I have amended the post
  28. That's the same weekend as the Newark Kit Car Show in Lincoln
  29. After a successful Dirty Duck Camping weekend earlier this year we have decided to hold a second Dirty Duck Camping Weekend for 2025. The event is open to anyone who wishes to join Sharon and myself for the weekend, we are expecting to see all the usual suspects and it would be lovely to see some new faces, The camp site is next to a Canal side pub. and Belvoir Castle is a 5 minute drive where you can get food and drinks along with visiting the Castle. The date for the event is Thursday 21st August 2025 to Monday 25th 2025 as it’s a bank holiday weekend. We have booked pitch 3 from Thursday to Monday. I suggest booking early to get pitches in the same area to the left of the site, link to Booking and site plan We will be eating in the Pub on site Friday evening and it would be great if you could join us, we will be happy to book your table and place your order nearer the time. The club will be funding a BBQ on the Saturday evening for members, along with a Quiz. A run is planed on Saturday to The Great British car journey DE56 2HE Please keep us updated on which pitches you have booked. Hoping to see you this year , Sharon & Kerry
  1. Load more activity
