I Just Cant Stop Tinkering
tractor
Surely there must be a way to fit without having to cut the bonnet!, Whiz has ST and his fits although I don't think his uses the VVT.
I do have a scoop you can have through to fill the hole if you have to!
Edited by unclechief
whiz has both vct and a bonnet bulge.
11149356_635510059926915_602546640172066
Edited by ozz
when fitting yhe flywheel i had a spiggot bearing all ready to put in then i noticed that there was already one fitted I didn't think that front wheel drive cars needed them very strange!!!!!
ooo no whent with longer thrust bearing CCT133 keith and andi have the longer pivot pin and both suffer from noisy thrust bearing just took it straight off my zetec engine
.133
Edited by tractor
