Starter motor can anyone help
I have had problems with my 2b ever since I bought it roughly 6 weeks.  I thought the engine had a lot of compression and the starter was finding it hard to turn over.
Today I replaced the starter motor and no change. I replaced the battery and no change.
locked at the connections all look ok.  Cleaned all earth terminals. No change.
voltage is 12.8 volts and turning over is 11.3 volts.
turning over is very slow / hardly turning??????
  • Replies 30
  • Views 7.5k
Most Popular Posts
  • Newer "oem" ones are 1.4kw.  Think this is the one I ended up with https://www.ebay.co.uk/itm/2-0-FORD-PINTO-LIGHTWEIGHT-UPRATED-STARTER-MOTOR-LRS00543-LRS00109-LRS00110/273796747058?ssPageName=STRK%3
  • It’s definitely timing.  Got her running and restarting sounds a Little lumpy. Going to my brothers later who has timing light.   i have noticed there is no vacuum pipe to the distributor?
  • That is a interesting theory.  The original starter did not conk but was lazy.  This is obviously down to timing “Thanks for the advise Ray”.  Will see what it dose tomorrow when fitted
i would come and help you but you are a long way away
what are the cranking amps and ah on your battery
Cranking amps not sure. It’s a 0.9kw starter motor and a 60 ah battery
Hi Richy, yes the power leads look good and good size probably 25mm cable.  Cables do not get hot on cranking.
i have 70ah and cca620 on mine i know its a bit on the large side but i have plenty of power to turn engine over
No reason to think the compression has changed.  It was just it would always start but very slow cranking.
thought to change the starter motor.
i can double up the starter cable if you think that’s worth a try
If you are suspecting a tight engine is it worth trying cranking with one ( or more ) plugs removed?
If doubling the cable dont forget to double the earth back from the starter to the battery. A pair of jump leads?
Talking of jump leads have you tried connecting a second battery in parallel?
Slow cranking can also be a sign of over advanced ignition.
It was a brand new starter motor??
I have put jumper cables from my wife's car with it running and its the same.
Yes brand new starter and 60ah battery
It's worth considering the point that Ian is making here. I experienced this with a 1380 tuned Mini (many) years ago. Try retarding the ignition timing or, alternatively, crank with the ignition electrically disconnected. If the engine turns freely with no ignition, you'll know it's ignition timing causing the issue.
Have you got any jump leads? Use these to add extra grounds between engine and chassis and / or gear box and chassis.  Quick way to tell if you need to improve the grounding.
