2,022 -
64
Surely it is a requirement to have it on the V5, and notify and produce appropriate documentation to DVLA if it is changed ?
I know this won't really help, but as I had my Superspec on axle stands I took the opportunity to take a picture of the clutch arm on my MT75. As you can see there is nothing like the obstruction you have and mine has full travel available (no idea what the audio cable is wrapped around the cable, I will have to investigate ) I can only assume that your clutch pressure plate is a lot wider than the one fitted to the Superspec (Rover T16 engine). I can't help you on what model clutch I have as Superspecs seem to odd. We had assumed Rover, but some have reported Ford and one owner who is presently stripping his down says the clutch has a Mazda part number. I should also note that I have a spare gearbox and the clutch arm on that is totally different to the one on my car.
Have you put a diode in the circuit ? If not the light could come on slightly if the alternator voltage is more than the voltage feeding the other side of the bulb. Normally they should be the same but depending on where the feed from the light comes from there could be a slight difference.
Looks as though the Stamford Car Show is planned to go ahead this year on the August Bank Holiday Sunday (29th). Fingers Crossed. As usual we should have a parking slot allocated for Club Members. Those of us who have been before should get an invitation code (mine has just arrived). For other people it is first come first served. They limit it to 500 cars (I think it used to be 300) but I would recommend booking early. It is technically free but they 'strongly' recommend a £5 donation to charity, which is collected by a chap at the entrance on the day. They also do a car rally during the morning but that is for very limited numbers and fills up quickly. We don't normally bother. Check out http://stamfordcarshow.co.uk/
They also like photos of the safety critical areas they can’t immediately see. Lower seatbelt mounts are a favourite.
I can see no reason why you want to fit a windscreen for the IVA. You have to sort out wipers, heaters, washers... Much easier to do all that after the test without the added hassle. Just my opinion
Good video, well worth viewing. Just be aware he uses the term ‘tie rod’ whereas we us the term ‘track rod’.
Mine was £40 Money well spent though as I won’t have to buy 2 new tyres in the near future. Had to take mudguards off though, as he couldn’t get his kit to go in above the wheels. Should also point out that Halfords refused to do it. Computer wouldn’t accept Robin Hood as a manufacturer and he wasn’t able to manually override it.
There is no exact answer but the general concensus on the forum has always been that you can't go far wrong with parallel with maybe a slight bias to toe-in if necessary. I was always used to measuring toe-in in degrees, but like the manual, my garage quoted it in mms. Mine was a 10mm out, whatever that means, now reduced to zero.
Weather not being kind to us so far so had to call off the last one. Weather might be OK on Sunday but my daughter and family are coming to stay for the first time in 15 months, so they will have to take precedence Will look again for the last week of the month.
Same here. I started to see excessive wear on the outside of the front tyres so had it checked at the local garage. Like you I had too much toe-in. Now corrected, and although my self centering was OK before, now it is quite aggressive and I have to keep a lot of pressure on the steering wheel during turns. But now extremely stable in a straight line. Just have to keep an eye on the tyre wear to make sure it is fixed.
I have separate relays for the hazards and the indicators. A couple of years ago I had the same problem as you, indicators not working while hazards were fine. It turned out the indicator relay had got wet after I washed the car. Thought I was clever by putting it inside a plastic bag to protect it, turned out to make it worse as condensation occurred inside the bag and soaked the relay again Once I figured out the water was leaking in from the windscreen wiper spindles I solved the problem by moving the relay to a safer place.
After 3 very successful meetings in April I am looking to do the same for May using my usual format, i.e. a nice drive then a picnic lunch at some beauty spot. The first one, subject to weather, is going to be a mid-week run to Foxton Locks (highly recommended, large car park and a nice walk along the locks). This one will still be limited to 6 people and at the moment is fully booked with my regulars, although I am happy to have reserves if someone drops out. The next one will be after the 17th, when up to 30 can attend so we won't be limited. Haven't decided on the location yet, but if anyone is interested let me know. I'm happy to make it a weekend if that would help anyone is still working and can't do mid-week. Al
I don't pretend to be an expert on this, but as I understand it for the IVA/MOT you need to ensure the front brakes lock up before the back brakes. In the semi-standard kit car fit with discs at the front and drums at the back this happens automatically. But if you fit discs to the back don't you have to add some sort 'brake balance' system to try and get the brake action loaded towards the front (70:30 rings a distant bill). Just some thing I have picked up over reading the forum for the last few years, happy to be corrected.
Does seem to be a bit excessive, maybe the voltage regulator (which also converts the AC to DC) is playing up. Can’t explain the voltage not dropping off.
My indicators don’t auto cancel so I spent a lot of time driving with the indicators on. So I fitted an industrial strength buzzer (I am told you can hear it from 50yds away) and a high intensity LED right in my eyeline. Result, no more driving with them on. In fact my MOT tester said they were the best he had seen The only downside is that they draw so much current that if one of the main bulbs fail there is no indication as there is with a normal setup where the indicators go double time.
Yes, with the engine not running the battery voltage is about 12V, once the alternator kicks in the voltage should be 13.5.-14V. Going off while cranking is normal, the system will switch non-essential stuff off to ensure full voltage to the starter motor.
As I understand it, one side of the bulb is wired to the 12V ignition supply and the other side to the alternator. So when you turn on the ignition the bulb as 12V on one terminal and 0V on the alternator side do it lights up. At the same time the current flow goes through the alternator exciting coils to earth. Once the engine starts the alternator starts up and puts 13V+ onto the other side of the bulb, so with only 1V across the bulb it goes out (probably also has diode in the circuit to eliminate any possible flickering at the low voltage). So if your light is not coming on when you switch on the ignition then either the bulb is not getting a 12V feed (which I think you have checked) or the feed from the alternator is not 0V. If it is wired to the correct terminal on the alternator I would think it is an internal problem with the alternator.
Beautiful day for a run out and picnic. Just a select few, with even the cars doing social distancing Thinking of doing it again on Thursday, one slot still available.
Had a practice run to Burghley last week which worked out well so having the second meet tomorrow. Again, 12:00 at Burghley House for a lunchtime picnic. Weather looking perfect. So far we have 4 attendees so still have 2 spaces left if anyone wants to come along and join us.
Now we are released back into the community, time to start getting together again. I'm going to run at least a couple of my usual picnic lunches either at Burghley House, Rutland Water or one of the local County Parks. Obviously limited to 6 people, so if anyone wants to come let me know your availability and if you will be accompanied and I will try to work out a programme.
I think actually have a slightly different wiring setup to Andy so I'll let him comment on his. As I see it, on his diagram he has both the signal & earth (Black/Grey) inside a shield. I actually have them totally separate and keep them physically apart, and in turn physically separate from the heater wires. So only the signal wire is a shielded cable and the shielding is earthed to the chassis at the Lambda end and NOT connected at the loom end. I suspect both methods are OK, but all I can say is mine works
I can't do one close to the pump, it is mainly within the engine block. But it makes sense to put one at the point where I disconnect the hose at the top of the radiator. Would be easier to bleed the system regularly,
