jaimo
Everything posted by jaimo
  1. jaimo
    Spotted
    Maybe went on both as was on way back from minehead butlins
  2. jaimo
    Spotted
    Sorry a42
  3. jaimo
    Spotted
    Spotted robin hood on a46 nr tamworth today about dinner time was anyone on hereand
  4. jaimo
    Newbie With 2B
    God dean how big is your garage
  5. jaimo
    Exmo Camber Problem
    Have you moved the car to settle the suspension
  6. Can get away with slight amount of play but not alot remove cap if one remove nut then bearing pack some grease in then grease bearing and refit Might have to pull drum off as bearing can be awkward to get out if that type fitted obviously
  7. If closer keith would of helped
  8. jaimo
    Front Wings
    You wonky keith never
  9. jaimo
    Fuel Issue?
    Check inlet manifold gasket and the hoses as mine was similar when fitted Also if got vac port on manifold is it connected to servo or blocked as will also pull air there
  10. Thats how my pinto sounded when sucking through bike carb manifold gasket due to injection head
  11. Its prob this one https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F183260324892
  12. Link not working
  13. I have a 4-2-1 fitted but have aquired a 4-1 as 2nd pic of peters above but the down pipes have been slightly flattened to miss steering is it worth fitting in place or if sell whats it worth
  14. Dont fit the lsd mark give it to me seriously lsd all the way
  15. jaimo
    Fuel Issue?
    No regulator its not needed as bike pump and a filter on pipe from tank before pump which is mounted in boot area
  16. jaimo
    Fuel Issue?
    Also just been out for a spin and wow wot a difference must of been going for a while
  17. jaimo
    Fuel Issue?
    https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F252678416785
  18. Did this happen since rewire
  19. Also i am led to believe cant fit a towbar unless qualifed due to insurance will be invalid
  20. Sticking by the sounds of it just had that problew with my r1 pump works then seems to stops tap it and works ordered new pump
  21. Trying to work out how it fits and operates
  22. jaimo
    Fuel Issue?
    I have just had this with r1 carbs and r1 pump ordered new pump as not working enough
  23. jaimo
    Patio
    What sort of money and area dan
  24. jaimo
    Patio
    Got to do patio never tried laying slabs or similar but confident to attempt decking i think but heard its slippy I got to clear grass area what ever way i go so any tips Or anyone local fancy lending a hand
  25. Yeah i too thought butresses and price
