speedtripledan
  1. I've been buying loads of bits from both sites. For a while now, all my type 9 v6 upgrade gearbox parts came from bearing kits
  2. As one of my many winter upgrades, I decided to buy a rose jointed quick shift gear lever from Matt lewis racing, to replace the standard cut down sierra one. It improved the shifts nicely but still had a little slop so I just fitted a brass gearstick saddle from bearing kits, I now have a gear shift with no play at all. Great cheap little mod. The other thing I have gone away from is short little gearsticks back to full height with a bit of weight on the end it makes the shifts so much easier and as a result of easier quicker....
  3. Just fitted a quaife atb differential to my English axle in the stylus, I read they were good and after a few miles of playing I can say for certain that they are good, really good.. with all the new found power when accelerating in a straight line the car was stepping out sideways if you didn't feed things in gently, now mash the throttle and it squats, wheelspins a bit and flies to the horizon at a rapid rate completely straight line and quicker than it was due to more traction.... the diff cost £536 a further £125 to have it fitted and completely refurbished with new bearings. Fitting the quaife atb is the finally to my winter summer autumn mods.
  4. Taking an engine out of whiz.s car
  5. Anyone know of a company that could fit my quaife atb diff? English axle. In the Midlands area? Arrow engineering in Chesterfield is near Impossible to get hold of...
  6. http://r.ebay.com/eRfJO2I've fitted this to the stylus the cooling ability of it is phenomenal. I have trouble getting up to temp now where as before it was marginal cooling. They come in 4core as well without the intercooler. Coolex will also modify to suit your needs. Worth a call....
  7. speedtripledan
    Zero Dials
    Because you live in Scotland
  8. What a stunning day to drive the kit cars! And I. M stuck at work
  9. Starting to feel like Keith now, everything announced this year I. M working...
  10. Which brake line is it plumbed into front or rear? Mine were like that until I moved it to the front lines...
  11. Just put 4 rainsport 3 on my caravan, got them on my mx5 aswell good value tyres
  12. speedtripledan
    Hoodstock
    Sounds good
  13. I use pilot sport 3 on my kit, really good tyres.
  14. I've done the opossite after 2 Tom Tom broke went to garmin. I now just Google maps on phone
  15. wasn't having a go mate, you just don't seem to have any luck with regards that kit car...
  16. I. D just give up and sack your engine builder....
  17. Raceline flywheel in mine. Handles the abuse I give it...
  18. Don't vent cap and crankcase into same tank, you could end up with problems. Vent the cap to atmosphere, if you don't like the smell drop a pipe down from the cap to Vent fumes away from your nose
  19. The eat less thing definately works. Lost a stone and 2 in 8weeks...
  20. The whine would blend nicely with the supercharger....
  21. Saw that and was tempted by the ratios. But straight cut would be a step to far
  22. Pinto turbo kit on ebay 332145683841 Nowt to do with me.... just saw it while looking for a new project...
  23. Is your coil getting good voltage on crank ? Failing that timing could be out, i put a pinto 180deg out once and it was dead as dead could be....
  24. speedtripledan
    Noisy Tappet
    My v8 used to start tapping every now and then always cleared on its own accord thou
  25. I.m working ! So won't be coming
