536 -
39
Everything posted by Foz
I'll do my best to be there Andi, hopefully in the kit - it'll be the first time it's been anywhere this year!
I'm assuming it's a pinto engine - if so have you got 20W/50 oil in it? Pintos don't like modern thin oil & rattle like a bag of spanners. The thin oil can also do serious damage to the engine if you run it for any length of time. Valve & cam noise on a pinto often sound more like metallic tapping rather than a knock. Can you tell if the noise if more from the head or the block? You can check the oil flow from the spray bar by dropping the cam cover off & removing the spark plugs. Spin the engine over on the starter & you should see oil come from all the holes in the bar, onto the cam lobes. Don't try running the engine with the cam cover off or you, your car and anything near by will get well soaked in oil. If the spray bar is blocked I would buy a new one rather than risk a used one. Steve.
Free to RHOCAR members !! I bought this drill from Aldi when my old faithful drill was playing up and only used it half a dozen times. All the bits & bobs should be with it, including it's box but please don't ask me to pull it apart & fit it back into the polystyrene. Lockdown gave my time to fix "old faithful" and now this new one is just gathering dust - if I stub my toe on it again it'll probably get chucked over the wall! If any members want to come and collect it from Stoke-on-Trent they are very welcome to it - it's not the best in the world but what do you want for nowt? Send me a PM if you're interested. If you're not a RHOCAR member this might be an incentive to join ? Steve.
What sort of fuel pump are you using? I had a problem with an electric pump & pressure regulator set up. The pressure regulator would adjust itself and increase the pressure to a point where it overcame the float valve, flooding the carbs. It took me a while to find as it was usually OK when you were driving around, but played up on tick-over.
Hi Andi, Just checked mine & it was £54.99 in June last year. It was £43.31 when I first took it out with them the year before but I think that was an offer of some sort. I'll be interested to see how much it is this year. Steve
Hi Andi - you're just trying to fool this old man by having this month's meeting next month aren't you ? But you can't fool me - I'm too stupid ! All being well I'll see you there. All the best mate, Steve
The chassis and front suspension on this looks an awful lot like my 2B, but the rear suspension is definitely different. My guess would be a stainless chassis 2B with modified rear end, possibly, well maybe ................ or maybe not!!!
If you do think of modifying your own seats I would strongly recommend you invest in some "hog ring" pliers (and new hog rings). They're only a few quid to buy, but they make it so much easier to get the seat coverings back on properly.
I bought heated seat kits from eBay & fitted them to my MG's seats. - Remove seats from car, remove seat covering, trim heat pads to fit & stick to foam, re-fit seat covering & then spend twice as long on the wiring - fitting switches & relays and running cables in ! To be honest I did it all in a weekend with no real problems & I reckon it would probably be a lot quicker & easier to do in the kit (I'll let you know if I ever get round to it). It was a couple of years ago when I did it but it only cost me about £50 at the time, which was an awful lot less than buying heated seats.
Looks good - with a bit of luck I'll be able to make it over on the Sunday.
Is anybody thinking of going to this ? The weather is looking half decent for tomorrow and I might be able to nip down for an hour .
I always used to enjoy Newark, I'm glad to see it's back on the calendar.
Guess who didn't check the website until he got to the George & Dragon? See you next time Andi, and yes I'll check where it is first!
Hi Steve, I run a 2Ltr pinto with Weber 40s on it & a Kent FR32 cam. With 32mm chokes in the carbs it is pretty well behaved on the road but probably loses out above 6000rpm. It all depends where & how you're going to drive it. Make the carbs too big and it will be a very thirsty pinto !
Don't know if anyone in the area fancies a look at this tomorrow? Breakfast at the Brewery The Third Sunday of every Month From March till September 9.0 am till 13. pm Classic Cars, Hot Rods , Bikes & Scooters All Welcome. At Lymestone Brewery , Mount Road , Stone Staffordshire ST15 8LL https://ukreapers.wixsite.com/reapers-uk/dates-#! I'm hoping to get down there but I'm not promising anything because things have a habit of going belly up as soon as I plan anything ! If the link above doesn't work try googling "Reapers breakfast at the brewery" Sorry about the short notice but I thought it was next week ! Maybe see you there, Steve.
I'll do my damnest to make it tonight mate !
What a brilliant idea, I've just "purchased" my list. We hardly used the kit last year & I'm hoping this will be the incentive we need to clock up a few miles this year.
Hi James, not sure how free I'll be on the Monday but I'll make it down there if I can. Steve
Sorry guys but I can't make this one - I've got to work a late shift on Monday. Steve
See you there Andi - if I can get the 2B sorted I'll come in it, which should ensure that it chucks it down with rain! I am open to bribes to leave it in the garage !!!
Put me down for it, I'd certainly be interested, or a different day if it suits anyone better. Steve
Clarke CFC500F 500kg folding hoist. (See Machine Mart product No. 020110095). Yours for £70. Very handy piece of kit when you need one - trouble is I've had it for 4 or 5 years and only needed it about 4 times, and I could do with getting the garage space back. It's in pretty good nick and you're welcome to come over and have a look at it if you're interested. Needless to say I can't post it but it will fit in the back of a large hatchback or small van. Steve
I'd certainly be interested in going, but I can only make the Sunday. Thanks, Steve.
