Pinto Problem
jaimo
  • 3 weeks later...
Right head done
Valves relapped
New valve stem seals
Head back on new gasket bolts and torgued correc
wudnt start so checked spark okay
Fuel ok
So checked compressions
60 psi on all 4
What the hell is going on
Think time to walk away
Any ideas guys
Chris not bad spanner skiiis
As everything done by the book
Job done hundreds of time
Stu with me at time of doing it so was all double checked
Just wondering if the diesel i used cleaned the bores too well now needs oil round them
Ive had a similar problem with my redtop once in the past.
My cylinder pressures were all between 210 & 220 psi,
then performance started to drop off drastically.
Compression tests eventually showed 130 &
it turned out the inlet vernier pulley had slipped & advanced the
cam by about 8 degrees. Luckily with no damage.
Resetting it to the marks I had marked on the vernier
got the pressures back to 210+ & the engine was back to its
hairy old self.
Double check the cam timing...if its out your inlet & exhaust will both be wrong.
Right oil in bores compressions double back to as it was before removed head so i believe the diesel i put in bores cleaned them too well
So charge battery bit more and go for start again
I will report back soon
