I can just get my manifold in and out on my monocoque but I haven't got a servo and I move the steering column extension out of the way. I then get the manifold out by twisting it round with a sort of corkscrew action as I manoeuvre it back and upwards
My breather goes up vertically out of the tank for quite some way then turns and goes vertically down to form a long U bend. I redesigned the fill point pipework so that I can get the hose filler nozzle well into it and don't seem to have slow fill problems
What's the weather been like over in Leicester? We were thinking of going to this show but the weather has been horrendous in Aldridge with floods all over the place! Bit concerned we may not get on of off the show fields if we go!
My rad has a bleed pipe welded in by the manufacture which goes back to the header tank. I've also fitted a bleed tee at the rear of the cooling system (the heater end), (heater? Wimp!). I have no problems bleeding the system.
The "top hat" (dummy strut) fits through the hub carrier and is clamped in place by a large bolt which has to be slackened to turn the dummy strut. The top hat is made from 2 pieces welded together, that's probably the weld that you can see. On my 3A I've fitted a safety bolt into the strut just in case the main bolt comes loose!
You're lucky that someone can repair it. When I had a chip in mine it was too close to the edge of the glass (20mm) for them to come out and fix it. Bought a kit off eBay and did it myself!
I agree with Andi. My carbs were supplied with 1.8 mains as they said that in their experience that was what was needed. Ended up with 155 mains after the RR session.
Well the car ran perfectly to and from Stoneleigh. So the fault looks to have been in the only 10cm piece of 30 year old wiring left on the car even though I couldn't detect a break in it. Let's hope it doesn't reappear!
Great weather, just like the old days! Thanks to all involved in doing our club stand.
I run a megajolt and edis system. This year I've had an occasional bad misfire such that the engine will not pull. When this happens the tachometer drops to zero. The tacho takes it signal from the megajolt dedicated tacho signal output.
Logic says that there must be an occasional fault on the PIP output from the edis to the megajolt?
Am I correct or is there something I'm missing?
I must be lucky with my car (it's not a superspec though). My pipework runs inside the top side rail of the monocoque body so it's well above all 4 calipers and I've never had trouble bleeding the brakes. I probably will now I've said that!
