379 -
15
Everything posted by maca
Hi Gentlemen, May I ask which one is going to give me the correct location as I am confused as to the correct answer? I have a choice of the 2-Roads, From richyb66 at the bottom of the W shaped lake (North of Cliff Hall Lane) From Andi on Cliff Hall Lane opposite (The Malt House Pub) tractor say's (next to cliffs lake site its the turning opposite the Malt house pub cliff hall lane) Do we have any other options as to where everyone is going to meet up? Kind Regards (maca) Martin
The Stamped in VIN must be marked on the chassis, frame or other similar structure which is not easily removable, on the right hand side of the vehicle when viewed from the rear. (see Notes 6, 8, 9 and 12) Note 12: Where the ‘stamped in VIN’ is stamped on to a separate metal plate it must be secured to the frame by a continuous seam weld around the entire length of the plate; tack or spot welding should not be considered an appropriate method of attachment for such a plate. To stamp the number into a tubular chassis member is not always practical but there may be instances where it could be stamped in another similar part of the vehicle structure which is not easily removable. You will also need the manufactures plate fitted with the details required as in Statutory Plates 18
Many thanks Richyb66, Weather permitting should be there, will be leaving home about 10.00
Any firm directions on where the site is on Tamworth road B78 2DL is in the middle of a field opposite Cliff lakes Road? Can't find a Pub called Tameside on google maps. What about Cliff Hall Lane opposite The Malt House? Can anyone give a true location for the meet up. As I was thinking of coming with my friend Saturday morning.
Hi Jon, I have sent you an email with pictures of mine while building. Regards Martin
Hi Jon, Just did a search on the forum and came across this that may help you with your boot area.
Hi Richy, As the rivets are along the centre tunnel sides I am sure that they will not cause a problem showing through the carpet. The seats hide some of the inner line of rivets. Jon is more concerned about the look of the underside of the car. Regards Martin
Hi Jon, Picking up the pieces from the former builder is always an issue of how much work you wish to take on. You can be very brave and completely strip the car back to the bare chassis as my Son and I did or skip over some of the things. (Drill out all the rivets and fit the other way round from outside to inside that would make it look better from the underside.) We removed everything including the floor, welded all the holes up and completely started again by fitting and drilling a new 1mm sheet to the chassis the other way up after many modifications to the chassis first. My car luckily had been assembled with self tapping screws in the floor panels. You need plenty of storage space to put all the items you take off and remember where you put it all. Have you a garage you can strip the car and be able to work in? Can send you pictures to big to go on here at the moment. Regards Martin
Model on dvla check as below:- Vehicle Details Vehicle make ROBIN HOOD 57 Date of first registration April 2000 Year of manufacture 1983 Cylinder capacity 1593 cc Even they don't have the correct details.
Hi Neil, The colour of the plastic has no bearing on the switch you require for your engine. Burton Power switch part no. XOPS9 is the correct part at £7.00 + delivery https://www.burtonpower.com/standard-oil-pressure-switch-1-4npt-xops9.html Regards Martin
Hi Mark, I believe that Nick & Neil are looking to replace the switch that warns when you have NO oil pressure, the dash oil light, not a guage pressure sender unit if my thinking is correct.
Try ebay type (oil pressure switch for Ford pinto engine) Plenty of choices, Fitting is 1/4 x 18 NPT Burton Power £7.00 + Delivery PART NO XOPS9 FITS ENGINE TYPE Ford Cosworth YB, Ford Cross Flow (Kent), Ford CVH, Ford DOHC 8v/16v RS2000, Ford Essex V4/V6, Ford SOHC (Pinto), Ford Taunus/Cologne V4/V6, Ford Zetec E, Ford Zetec SE
Kit Spares https://www.kitspares.co.uk/ Robin Hood 2B weather Gear Images are for illustrative purposes only Product Code: EXT0031 Availability: Out Of Stock Delivery Status for this item is 5-6 weeks Price: £636.00 inc VAT Ex Tax: £530.00 Or try Soft Bits for sevens at- https://www.softbitsshop.co.uk/
I payed £148.50 for 6 months from 1st June2020
(Before Waterless Coolant) you need EVANS PREP FLUID to clean your engine. Not cheap to change from water to waterless Just under £100.00 to prep and fill with 5 litres. Then you will need another 5 litres to fill your system so would be looking at about £150.00 to change over.
Hi to answer your question the oil pressure switch is shown, and would be wired to the dash warning light marked oil. that lights when you have NO OIL Pressure, when you switch on the ignition and should go out when the engine is started. If you want to fit an oil pressure gauge then you need a Tee piece for the pipe or sender unit to fit.
Here's a better picture the correct way round. Too the right of the oil filter is the PCV Valve above that is the manifold water temp sensor. Too the right of the engine mounting is the oil pressure switch. Hope that helps you. You will find the water temp gauge sensor above the distributor area in the picture.
Hi Max, Welcome to the club, I have a 2B and have a 4-core mini radiator, having an expansion tank piped from the stat housing and an overflow bottle from the rad pipe see the picture.
Just had a look on google and came across this on you tube. Wiring and Electrics on the GBS Zero explained…… - YouTube
Looks like the body work came up well after the sand blasting. Can I please dust off the remaining sand ?
Hi Lee from my message to your previous request I am more than happy to help you fill in the details as stated. You need to fill in form IVA 1C Fill in form IVA 4 section 1 question (3 tick) question (4 tick) section 2 questions (1 to 6 tick) All Sign the application and Date ( This date can also be the date of completion) You may also need to send in copies of reciepts of parts purchased and some pictures of the build. Do not send any other documents with your application at this stage. When you have your IVA Pass Certificate you will then need to apply for registering the vehicle and then is the time to send. V627/1 V55/5 IVA PASS V5C of donor vehicle The registration fee £55.00 The road fund payment And any other documents they may require.
Hi Jon, Not sure if GBSC (https://www.greatbritishsportscars.com/) may be able to help you out with any panels or parts that you require? You could give them a try as they still stock some items or maybe able to help you. Regards Martin
Hi Jon welcome to the club. Now to the videos you can only describe them as a budget edition performance at best with the dog liking to get in on the picture as well. Richard & his wife made a brave effort to explain how to do the basic's in know particular order. The car kit at the time was a very low price and I could see that their video making left a lot to the builder to understand. At least the builder of the kit had a help line to phone if they could get through. Regards Martin
First option eBay item number: 233580963526 Multi-buy Buy 1- £3.07 each Buy 2- £2.89 each
