IanS
Everything posted by IanS
  1. IanS
    Temp
    I have no holes in the bonnet and do not have it proped up Viscous fan was too far from rad to have major efect. Fitted electric fan tight to the rad and it pulls enought air to keep temp OK at all times. deleted the Viscous fan as not working and did not want to make shroud that might not have worked. Standard 2.0 pinto with standard DGAS carb, there is reasonable area for hot air to exit down the sides of the engine and back through the transmision tunnel and past the diff. Have you ever looked at a modern cars rad instalation end wondered where the air went, it does not take a lot or area if the fan is tight to the rad.
  2. Fuel guage. If you have a ford sender then some also had a switch that connected to a fuel low light. They sometimes also had a second scale to provide input to a not very acurate mpg display. Check the sender conectrions.
  3. IanS
    Pinto Coil Wiring
    Looks like a suppressor to cut noise to the radio
  4. IanS
    Engine Project
    already been done. Think thrust SSC landspeed record holder. Might want to upgrade a few other things like brakes.
  5. Those look to be the wheels that Robin Hood were selling as an option towards the end before R Stewart sold the company. He must have got a masive job lot at knock down prices.
  6. IanS
    Speedo
    Probably a bit late but I got a full set of smiths guages from a triumph dolomite at a scrap yard for £25. The speedo drive will connect to a smiths speedo with a little help. This was 18 years ago so may not be many doners left in scrap yards.
  7. IanS
    Oil Pressure Light
    My understanding is that cars are required to have very little. Speedo, Main beam warning, Indicator warning, Highintensity rear light warning. If it does not affect other road users then it is not needed and not tested.
  8. Shoud this be pinned?
  9. IanS
    4.5 Gallon Fuel Tank
    I glued (araldite) a baffle round the pickup in my tank. Roughed up the surface with 30 grit to let the glue bind. Baffel is U shaped with the top pointing left and stopping approx 10mm from the left side of the tank. Pickup (and guage sender) near left hand end, filler near right end. Had sierra filler pipe into tank as designed by robin hood, filler stuck 2+inches into tank so the top 2+inches unuseable. Drilled a couple of 12mm holes in the filler pipe just into the tank and now can fully fill. Guage goes up and down a bit on long corners but I just ignore that.
  10. IanS
    Which Battery
    My view on batteries is that cheep is always a disaster and last no longer than 1 day beyond guarante. So look for a supplier that will still be here in 5 years and buy thier Mondeo 2L 5 year battery. If you only run the car occasionaly look to using a battery maintainer charger.
  11. RS had a lot of the early cars shorten the early 3 joint prop by removing the middle section. The Sierra had donut behind the gearbox to UJ near center body mounted bearing ( kept the donut straight ) to UJ near the diff. removing the center section gave a cheep way of shortening the prop the problem being that the donut now had to cope with more than 1 degree out of alignment and failed. Numerous coments in BOYS IN HOODS from the mid 90s about how loud the shaft was rattling round the tunnel when the donut gave out. I am not aware of any actually bursting out of the tunnel but many large dings.
  12. Before buying check the width. The mono cars had the transmission tunnel offset approx 1 inch to the left to give more room on the drivers side for the peddles.
  13. IanS
    Hydraulic Clutch
    Bigger bore master cylinder pushes out more fluid per inch of pedal depression. More fluid pushes slave cylinder further disengaging clutch sooner. So for early clutch release and a heaver pedal fit a larger bore master cylinder.
  14. Had a great time. Thanks to everyone involved in the organisation. It is good that the club is still going strong in my 18th year as a member.
  15. The thing that R Stewart (creator of Robin Hood) was that he understood that there was a good market for basement price kits. Resale price is lower but you do not loose much. I am not sure that he has a sucessor. I would still like a GT40
  16. Reverse is selected back from 5th on MT75. Reverse is hard left and forward on type 9
  17. IanS
    Brakes
    If the bleed nipple is at the bottom then it is very hard to get all the air out. You probably need to get the pistons all the way in to leave no room for air whilst bleeding. Wedges can help drive the pistons back.
  18. IanS
    O M G !
    In my build removing all the unused bits of the loom more than halved the weight of the loom.
  19. I said warm not boiling
  20. I remember outdoor toilets in winter. No flush as the cistern was a block of ice. Water trap iced over. Take out a large pan of warm water to flush.
  21. All we need is a couple of sealing quick release connections and it can be plumbed into the central heating. Nice warm seat and a pre heated engine. Absolute top of the line luxury. Instead of fitting electric charging points all over the country we need to agiate for water heating points. RHOCAR for PM
  22. Smiths guages required a voltage regulator. The smiths ones were bimetalic and could stick. Demon-tweeks have an image in thier catalog
  23. Do not forget that most electrical guages need a voltage regulator to keep the reading stable. Ford guages run of a stabilised 8V supply, if you are running direct off the battery at 12 to 14 volts the reading will be high.
  24. IanS
    Vin Plate
    87 might be the age of the donor. My 97 registered car shows as 83 on the V5. At that time there was no standardisation in registering kit cars. I am correctly registered and the build was finished before SVA or IVA was implemented.
  25. IanS
    Seats
    One other thing to check is that some Robin Hoods have the drivers side wider than the passenger side to give more room round the pedels.
