richyb66
Area Secretary
Everything posted by richyb66
  1. A few years ago I worked closely with Dinol at an OEM who were looking at rust prevention treatments. As part of this work (and also my current work), I'm involved in corrosion testing and the teardown of test vehicles which can be enlightening to say the least. I've been very impressed with the quality and performance of the Dinol products and it appears that they have a number of treatment centres located nationally: http://www.dinitrol....entCentres.aspx It might be worth giving one of them a ring. Assuming that you're looking for corrosion protection, the cavity waxes offer better protection than traditional underseals and have a "self healing" capability which means that unlike underseal, they recover from stonechips and similar damage. In essence these products are similar to Waxoyl but with far superior performance.
  2. Not yet, but then someone has to be the first Bob!!
  3. You clearly need to try harder. I was done for 102mph (in a 70) on the A46 near Kenilworth - £60 and 3 points. Mind you it was in 1986. The police has follwed me for about 5 miles and when they finally stopped me, the copper asked me if the car had been modified to increase it's performance. When I'd finished giving a run down of all the modifications, all he could say was "Well it seems work, maybe a bit too well though!!" I elected to go to court and when they read out the police statement saying I was observed doing between 96 and 102mph in a Hillman Avenger, some in court actuallly laughed out loud!
  4. Big support from the Leicester lads already, hopefully a few more people from my own area will be joining us!!! Keith, Kerry - might be worth you guys doing a single booking for the pair of you. The Terfyn in getting booked up but the Llys Olwen also comes highly recommended (outstanding breakfast apparently!!)
  5. Step 1. Sell the helmet but keep the box. Step 2. Put bubblewrap around childs head. Step 3. Cut eye and nose holes (mouth hole optional). Step 4. Fit box over bubblewrap. Step 5. Cut hole in box to align with holes cut in Step 3. Step 6. Form a weather tight seal between the base of the box and the child with duct tape.
  6. richyb66
    Axle
    Atlas axles are basiclally heavier duty than the Enlish ones - bigger and thicker axle tubes, bigger bearings and crown wheel / pinion. Theyt're also quite a bit heavier. There's a downloadable article here that's worth a read: http://www.classicfordmag.co.uk/2012/01/04/definitive-guide-to-atlas-axles/
  7. Yes, the more the merrier - if you turn up, you'll definitely get fed so the catering isn't a problem.
  8. M18 x 1.5
  9. richyb66
    Overheating Tin Top
    The leaking is usually quite subtle so you don't get pooling coolant, it just comes out as steam which you're only likely to spot on a cold day. Feel under the tank, you can sometimes get coolant residue on the tank which is an easy spot. Tank is probably main dealer only but should be under £40 (can't remember what the last one cost me but it wasn't too bad). Part number is most likely 8E0121403 but dealer will confirm from VIn or reg number, get a new cap as well for the extra few quid. Second had not worth bothering with, they could be just as bad as your current on
  10. richyb66
    Overheating Tin Top
    Cracked coolant header tank - I'd almost put money on it. I've had 2 of these, one on a 1.9tdi Audi 80 and the other on my S6. The cracks are usually very small on the underside of the tank so not immediately obvious but the coolant boils out slowly and the cooling system doesn't hold pressure so it boils easily. The tanks are suprisingly cheap fortunately.
  11. Sounds like it's the 1950's again. Not things most people expect to be doing on a daily driver, still at least he'd still have the Zero to use when he can't get the Mazda started. Personally if I was looking to spend the (roughly £2.5 to 3K) that a reasonable RX8 seems to cost, and was looking for something to use every day, the Mazda wouldn't be in my shortlist. As someone who seems to make a career out of running expensive, tempramental cars as daily drivers, it's not something I'd generally recommend unless you're completely mad and also have deep pockets.
  12. My neighbour ran an RX8 for a couple of years. The issues he had with it were many and varied including hot start problems, coil packs and starter motors. He's a car nut and dead handy with the spanners but even he was getting tired of it. and wished he'd never bought it. No doubt there's plenty of people who run them with few problems but when they do go wrong you need either deep pockets, patience or a combination of both. Like many things, they're great when they're running well - something these don't do that often apparently. If you do get an RX8, you'd be more likely to need to drop the Zero engine in in, not the other way round.
  13. This thread is starting to sound like a broken Record.
  14. I'd prefer to think of it as an evening kick off.
  15. Another thought, badly worn lower suspension bushes on the LHS could cause pulling to the left because the whell that side will tend to move rearwards under power.
  16. Presume that no other parts have been changed on it recently?
  17. It's about time you got your IVA application in - it's only 9 weeks until the Wales weekend!!!! Do you need a hand with anything - assistance is always available.
  18. richyb66
    Disaster!
    It's worst for those left behind, thankfully in this case there doesn't seem to have been a saucer.
  19. Yes it could be converted, but it's quite a lot of work. If you've still got to get it through IVA then my advise would be to stick with the currunt suspension and concentrate on getting it on the road. They'll be more than enough jobs to keep you busy as it is, without adding to them. One of the reasons so many car end up unfinished is people forget how much is involved and then loose interest. If you minimise the work required to get the car on the road, the experience of driving it might spur you into a suspension change as a later winter upgrade.
  20. That looks an ideal candidate.
  21. How about buying an unfinished 2B off Ebay, one of the ones that's 95% complete and only needs a couple of weekends work. We could buy that, finish it off and then raffle it off. Only joking. What about getting one of our "longer term " builders who's nearly there but struggling to finish their car off and doing it for them.
  22. There's plenty of places that'll make flexi hoses up to your specification. About 3 years ago I used Mtec racing in Tamworth to do mine and as they're close to you, it might be worth giving them a call to see if they'll make some up while you wait. That way you know that what you're getting is correct. http://www.mtec-racing.com/
