This post started as a request for information but is now basically an advert from a non-member.
As the primary interest seems to be the Sierra, not the kit, I think it's a good time to lock this thread.
Anyone interested in either the Sierra or hopefully to kit can contact the seller via the Gumtree advert or message them.
Do your relays click when you operate the relevant function? If they do, then the issue is probably the relay output wiring but if they don't, it's the switched feed to the relay.
What harness are you using, the original Ford one?
Wiring for the wipers is in this thread.
All the other wiring info will be on the forum somewhere, you need to use the search facility and be fairly specific with the search terms.
Just thickening the floor won't increase the stiffness as much as adding some angle. All you'd be doing is adding weight. I think you're better off just keeping the normal floor and using angle or box across the floor where the front and rear seat fixings go through.
Christmas is almost upon us and the few shows we have had this year seem long ago. However is good to see a few new members joining the club in November. Welcome aboard to the following people:
Duncan H duncthediver Holmfirth
Richie C Richie Redcar
Derek P Derek1978 Port Talbot
6.5" and 7" diffs have a single long bolt going from side to side across the top. 7.5" has 2 separate bolts.
The sizes refer to the crownwheel diameter.
I've been made aware of a Kaig for sale but have very few details other than it was build by Robin Hood from an MG Metro donor and was the promo vehicle for their launch.
If anyone is interested, message me and I'll pass your details on.
Next Wednesday (24th) , 7PM onwards, Malt Shovel Pub, Coventry Road, Nr Stonebridge, Coventry, CV7 7HL
If you've just got your MOT and possibly been remapped, I expect to see you in in it......
Just saying!
Can't you swap the rose joint and adjuster for a rose joint with a female threaded end. It won't be as easy to adjust but it's not like you're adjusting it regularly.
Most people SORN their cars over the winter, I'm pretty sure someone could lend you a set for the test. What width and ET are the current wheels and how wide are the tyres?
I like wiring but even I wouldn't make a harness from scratch. You need to be a special kind of masochist to want to do it when they're available off the shelf for not a lot of money.
There shouldn't be any relays on the side lights and they should be battery fed, not ignition (so they can be left on for parking).
What harness do you have?
