Foz
Committee
Everything posted by Foz
  1. I would say "impressive". I might also say that it looks like they're queuing up for their turn in the garage 🤪🤣
  2. Ah the joys of kit cars 🤪 Glad to hear you've got it sorted - just in time for some good weather.
  3. Welcome to you all, the weather seems to be picking up so we can start getting out and about again & hopefully meet up with some of you.
  4. Glad you're sorted - don't worry, at my age I may well have senior moments but it's OK because I don't remember them 🤣
  5. You're just trying to confuse an old man aren't you 🤪 I've had to look at the manual ! The TDC pointer on the backplate behind the cam sprocket should line up with the dot on the head when it is nearest to the crankshaft. At this position the pointer is pointing up, away from the crank. I don't see how it can line up with anything when it 180 degrees out from that, as it would then be above the camshaft, in fresh air. There is a picture in my Haynes manual (19.3 on page 2A.12) which shows it, and that is how I remember it (although my memory is not as young as it was). I don't have a pinto handy to check but I'm sure it's correct. Hope this helps, Steve
  6. Foz replied to Paul Shortland's topic in Kit car related
    Hi Paul, welcome to the club. I suspect that you may have to put it through an IVA test, particularly as DVLA are now aware that the V5 doesn't match. The only thing I can think of is if you have any paperwork on the original build showing any tests it may have had at that time - this might then give you something to present to DVLA ? Good luck, Steve
  7. Have a look at some of the marine / boat builder websites, they do a range of stainless hinges in all shapes and sizes, designed to survive sea water.
  8. I must learn to type quicker - either that or slow Al down 🤪😀
  9. Not sure what you mean by J registration. J at the start could mean it used a 1970/71 donor car (unlikely), J at the end could mean a 1991/92 donor and is most likely if a Sierra was used. What is more important, as Phaeton says, is what is recorded on the V5. If it's a genuine seller they'll be happy to tell you.
  10. Foz replied to Foz's topic in News
    There's something odd going on - I got this message a couple of days ago, closed the page and then went back to it a couple of minutes later and could just read it. I wonder if it just pops up now and again ???
  11. Foz replied to Foz's topic in News
    Don't know if it's something you've said 🤪 but I've tried the link on a couple of devices and it just lets me view it. If you (or anybody else) still has problems let me know and I'll see what I can do.
  12. Foz replied to Foz's topic in News
    Thanks Derek, I was just going to post the link but you've beaten me to it 🤪. I'm not sure why there is only pictures of me - presumably nobody else is as handsome ............. OK, maybe they all said no ! As you say, it makes some good points about kit cars and we've got a mention in a national newspaper which can only be good.
  13. Foz replied to Foz's topic in News
    Newsflash, I've just had an email - it should be online tomorrow but might not make the paper until next week !
  14. Foz posted a topic in News
    Just to let everyone know that there is a kit car article in the money section of tomorrow's Telegraph newspaper, both online & hard copy. I believe it's mainly about the financial aspects of kit car building and ownership, but don't quote me on that 🤔. I had a chat with Joe Wright who's doing the article so hopefully the club will get a mention and maybe a photo, although, if I'm in the photo it might frighten people off !! I don't know exactly what's is in the article but they say any publicity is good publicity don't they ? Steve
  15. Most pedal boxes I've seen recently seem to use 2 brake cylinders and a balance bar, I don't know of any single brake ones. I ended up modifying the original Sierra pedal assembly in mine. Have you had a look at Compbrake (https://www.compbrake.com) - they make pedal boxes and may be able to customise one to suit you. Their prices are reasonable - I had a fuel tank made by them, to my design, and I was impressed with it & their service.
  16. Hi Russell, welcome to the club. Which model Robin Hood do you have - the hood is not quite the same for all models and the radiator fitting options are different. Options on the hood - you can make your own or you may drop on a second hand one for your model, (I'm not sure if GBS still do a hood for the 2B) alternatively you can get one made, somewhere like "Soft Bits for Sevens" is sort of in your corner of the country and will give you an idea of prices. Have a look at Derek's article in the Autumn 2023 magazine for ideas on making your own (you'll find the mags in the Member Lounge section). As to the overheating - can you give some more info. - what engine do you have? does it overheat if idling or only when given some stick? does it blow coolant out? Any other information might give us a clue what to suggest. If you have a search on the forums (search box, top right of page) for "overheating" you'll find lots of previous problems members have had which might help you. Try this post for starters - Steve
  17. There are a number of options depending on a few things such as what size pinto you're running, what state of tune and how much you want to spend. If you're running a fairly standard 2.0 a then the DGAV 32/36 is a popular option and (I think) it fits the stock manifold.
  18. You can drill as many as you like if it's your thermostat 🤣 In my 2B's pinto I used to drill one hole of about 3 - 4mm, positioned so that it would be near the top of the thermostat when it was fitted. I found that this was enough to prevent air locks without defeating the operation of the stat. Steve
  19. I've received this message from Wilksy - is there anybody out there who can help him with rebuilding one of these carbs ? Thanks, Steve Wilksy Foz DFTH Carb - Help required. Idiots mistake - I have stripped down a 30/34 DFTH ex 1987 Sierra 2.0 carb to give it a good and thoroughly needed clean as well as modify it to run on basic engine electrics and manual choke - yes I know not the best solution but necessary funds wise to get this twice frustrated project mobile for an IVA. Idiot that I am I didn't make note or take pictures when I stripped this gunk laden piece of history. Now looking more presentable and re-gasketed I'm scratching my head on the operating spindle build sequence. The Haynes Sierra manual is about as useful and informative as a chocolate fire guard whilst DFTH exploded views on the net appear to vary, now having got Webers exploded view its better but like the others doesn't cover the small part details of the operating shaft. I have worked out the cams and levers and have a good understanding of the spacer collars and springs. Where I'm totally stuck is the positioning in the assembly sequence of the small profile bore washers and discs which appear to hold the collars / cams / levers in their required positions. Does anyone have a picture/s or sketches which could assist me ? Thanks in hope Wilksy
  20. Anyone is normally welcome at the meets, just turn up or contact Alan (Alantoon) for more info.
  21. Hi Daniel, only just realised you're a new member - welcome to the club 😀
  22. Have a look at this :- Stat.pdf
  23. I doubt it - check the date.
  24. Foz replied to Tickover's topic in Chassis
    It looks like a coil-over, so I would normally say that you don't need to compress the spring ............. but it doesn't look like a "normal" coil-over so it might be a RH "special" in which case it might be prudent to play safe ! Sorry for not being very specific but, hopefully, somebody else will recognise it and be able to give a definite answer. Steve
  25. Hi Harry, I can't fully make out what's on the end there but it doesn't seem to match anything in their current catalogue - have you tried contacting them directly? They're normally quite helpful. http://www.newman-cams.com/ Good luck, Steve
