I got a mate of mine to 3D-print me one but it doesn't have holes for stalks - however, I have the STL file for this , if it helps? You could get someone to print it for you and then cut out holes, maybe?
I dont think engine speed when starting has anything to do with the spark- it's all about the starter motor. As Bob says, earth's are the first thing to check but I had the same problem (on my Zetec) and it proved to be a dodgy starter motor. Replaced it and all good.
Yeah but he never had to scrabble on his hands and knees through bits of old tape/swarf/oil to find that 10 mil socket he'd just dropped through the engine bay
Note the text in red....this is an alternative option, NOT a requirement IMO. The actual requirement only says this:
4. The rear fog lamp(s) must only illuminate when dipped beam, main beam or front fog lamps are lit (see alternatives in Notes 3 & 4)
I got through IVA (in 2017) without that but I don't recall him actively testing it either.
However, I'm pretty sure that when I read the IVA manual, it was not a requirement, from my understanding, so I was never thinking about it during the test.
Almost certainly the side-arch only. There was at least 1 person who failed IVA because the repeater was on the side panel (although not sure exactly where - might be a location where it is ok?).
Look in the IVA manual, there is a complicated looking diagram showing where it has to be visible from.
This is a garden shed which has a lawnmower and a few other odds and ends - will that cause condensation? I won't be spending any time in it, I can only fit a basic 6'x4' shed.
Advert says it is galvanised?
I need to update my rubbish wooden shed (it was cheap) and I don't know whether to go plastic or metal -any opinions? Metal ones seem much cheaper, which I was surprised by...
As Ian says, if you try keep the same amount of rubber, the wheels just won't fit under the wheel arches and you'll affect the speedo. If you keep it low profile, you'll make minimal different to ground clearance and the ride will be even harder than normal (if that is possible ).
I used small washers that were about the same size as the rivet head and small enough to fit inside the popper body - run those down the pop rivet length and they act like an extension to the gun head (sorry, tricky to explain).
I just drilled very slowly and I did hit the glass a couple of times but it's tougher than you think (as long as it's modern, laminated stuff), so you should be fine.
Details here:
https://zerolifebuild.blogspot.com/2017/12/a-roof-over-my-head.html
I left the ECU (Emerald) out for my first startup so I could check it worked before final fitting (see here: https://zerolifebuild.blogspot.com/2016/08/a-beating-heart.html) but after that, yes, fitted on the firewall and yes, it (well, the Emerald ECU - don't know about others) does have a basic map which should allow it to get started.
If you want it for track use, I believe it needs to be accessible easily, so under the bonnet is no good. Even for road use, you really want it in an emergency, so needs to be in the cabin somewhere. I've not got one, so can't help further..
