818 -
77
Everything posted by Foz
If you can get hold of an early version of the Haynes manual for the Sierra it will give you lots of information on the Pinto engine. The later versions of the manual have less info. and more "take it to the dealer". You can usually find them on eBay for a few quid.
Most 2Bs had (or ended up with) coil overs on the rear. GBS still do the adapters that go in the bottom of the roll bar tube and Gaz coil-overs. https://kitspares.co.uk/collections/all/products/copy-of-robin-hood-front-wing-bracket-et35-os https://kitspares.co.uk/collections/all/products/2b-shock-absorber-set#description A few years ago I contacted them and they were happy to sell me just the rear pair of coil-overs when one of mine had sprung a leak. I don't know if they would still do that.
As per Bob, is this what you're looking for? https://www.carbuilder.com/uk/sierra-master-cylinder-brass-remote-reservoir-adapter
Just a "bump" for this - anyone else interested or any other comments ?
Yes, I doubt that they would fit. The 2B's tubular chassis wasn't what you'd call "standard" size so I'd definitely measure everything at least twice first.
- 2b
- bonnet and scuttle
(and 1 more)
Tagged with:
CBS do a wide range of trim and adhesives https://www.carbuilder.com/uk/trim Woolies is also worth a look https://www.woolies-trim.co.uk/c-17-trimmings There are a couple of places on eBay as well but you'd have to search for them - sorry, I can't remember their names. Hope this helps, Steve
OK Andi, I'll be there from about 7pm and, don't worry, I'll drink your beer for you !
Many unleaded heads have been modified and had hardened seats fitted to the exhaust ports. If you're taking the manifolds off you may be able to look up the port and see if you can spot hardened seats. A "borescope" would be very useful for this but a good torch, a dentist's mirror and possibly standing on your head might get you there.
Have a look at this - https://www.ebay.co.uk/itm/143548367716 It's small, light and 50 Amps rated. I've bought one of these to replace the standard Ford item on the Cobra. I fitted something similar on the 2B's pinto which worked well. Bear in mind that you'll have to modify the existing brackets to suit and may need to provide a +12V ignition feed to it if your original one doesn't have one.
Sorry Andi, I can't make it last month I'm assuming you mean 23rd May ? but more importantly - who's turn is it to get the beers in ? See you there mate.
Hi Darrell, thanks for your thoughts. Phil's trying to get some idea of interest levels at the moment, so we can see if it's worth proceeding. There are lots of places that do track days so, if there was the interest, we could possibly look at different venues as well. To try and answer some of your comments (I would have to confirm the details with Phil but ...) I would expect that you would get to do multiple runs, each a run of 7 laps. Normally 7 laps flat out and you want a break (so does your car). After each run, I find that by the time you have calmed down, checked your oil & water (possibly your underwear too), and got ready to go again it's already time to form up for the next run. I appreciate what you say about the distance as it is about the same for me. I used to trailer the 2B so didn't need to worry about it surviving so much, but I don't have a trailer for the Cobra so I'd either have to hire one (expensive) or drive it there and back and be a bit more careful. The beauty of Blyton Park is that, as long as you don't go silly, you're unlikely to damage your car. Rain doesn't normally stop play, but I'm not a big fan of a wet track and I tend to wait for it to dry out a bit. Steve
Seems that lots of people have looked at this but nobody has replied - let us know what you think please (good or bad) 'cause we ain't psychic Thanks, Steve
By now all members who opted to have electronic magazine delivery should have received a "pdf" copy, and all others should have received a hard copy, of the Spring 2024 magazine. If anyone has not received a copy please let myself or Alan Richey know and we'll try to sort it out for you. We now have just over 2 weeks before the AGM is held at the National Kit Car Show at Malvern (Sat 1st June) and hopefully we'll see lots of you there. If you wish to have anything discussed, or would like to volunteer as Events Secretary, please follow the instructions in the magazine. Steve
I like Blyton Park - we've done a few track days there and we would definitely be interested in coming out to play. To any members who don't know the track it is a good, fun track which is relatively safe. There is plenty of run off around most of it so should you exceed your talent level you can slide off and look sheepish without hitting anything solid. I know, I might have slid off on the odd occasion
Increasing the master cylinder diameter to 1" will need approximately twice the pedal pressure for the same pressure onto the brakes. Can you fit something like this from CBS ? https://www.carbuilder.com/uk/075-brake-and-clutch-master-cylinder-with-reservoir
Moving forward (slowly) into the "paperless" age, we have just sent out PDF copies of the magazine to all members who were happy to receive it in that format. This is the first time we have tried it so we expect a few ‘glitches’. I could try telling you that these are deliberate features of the system designed to ensure security, equality and privacy but you wouldn't believe me If you haven’t received a copy (please check any ‘spam’ folders first) then notify Alan Richey (username alanrichey) and he will send you a copy. Thanks, Steve
The club’s AGM is planned to take place on Saturday 1st June 2024 at the National Kit Car Show, Three Counties Showground, Malvern at 3pm. We are currently waiting for confirmation of the location of the club stand & the room booking so please keep an eye on the forums for any updates. The current Committee are having to state their intentions for re-standing or standing down at this year’s AGM as follows: Standing for re-election Kerry Allen – Club secretary Tony Godden - Treasurer Alan Richey – Membership secretary Steve Foster – Chairman Willing to stand aside Steve Foster - Magazine Editor Those listed as standing for re-election wish to remain on the Committee and will do so unless someone stands against them and receives a majority vote at the AGM. Those listed as willing to stand aside have expressed they are happy to continue with their role on the Committee but may also be willing to stand aside if a formal nomination for a suitable candidate is received prior to the AGM. As such, nominations for these positions are encouraged, but not required for the club to continue to operate. There is also a currently vacant position on the committee for the role of Events Secretary, and a vacant position for the role of Area Secretary for Scotland. Previous attempts to fill roles at the AGM itself haven’t always been successful so it’s important that we advise everyone of the situation in advance, rather than trying to press gang someone on the day. I would like to remind everyone that without an events secretary we are currently struggling to arrange or support events and may be unable to do so in the future. If you are interested in either of the positions and wish to discuss what is involved please contact myself. Finally, below you will find the instructions for submitting nominations, constitution changes and points for discussion at this year’s AGM. Commitee Nominations If you would like to apply for committee positions, you can do so by emailing secretary@rhocar.org Please use the subject line - "RHOCaR - *Your first name and surname* Nomination" Then enter the text below in the body of the email, with the relevant information completed: I (Print name), Membership Number Offer myself for election to the Committee of RHOCaR, the UK Kit Car Club for the following role(s). Position I will / will not be able to attend the AGM. Nomination supported by Name, Membership Number Seconded by Name, Membership Number Please also CC your nominator and seconder into the email if possible. Nominations will be verified using the email addresses registered with the club. Club Constitution If you would like to propose any changes to the club’s constitution, to be discussed at the AGM, please do so by by emailing secretary@rhocar.org Please use the subject line - "RHOCaR Constitution Changes 2024" Then enter the text below in the body of the email, with the relevant information completed: I propose the following changes to be made to the constitution/rules of RHOCaR, the UK Kit Car Club. Proposers name, Membership Number: I will / will not be able to attend the AGM. Seconded by Name, Membership Number: Please CC in the seconder to your proposal if you are able to do so. The latest Club Constitution can be found here : https://www.rhocar.org/index.php?/forums/topic/50680-club-constitution-and-rules/#comment-411737 You’ll find it under Club Information on the forums, or just search “Constitution”. Points for discussion at the AGM If you would like to raise any points for discussion at the AGM, please do so by by emailing secretary@rhocar.org Please use the subject line - "RHOCaR 2024AGM" Then enter the text below in the body of the email, with the relevant information completed: Points for discussion I (Print name), Membership Number wish the following points to be raised for discussion at the RHOCaR, the UK Kit Car Club AGM: Hopefully the weather will be kind to us this year and we will see a good attendance at Malvern. It would also be nice to see members attending the AGM if they can. Everyone on the Committee is a volunteer and wants the club to be run for the benefit of its members but we need feedback from you to make that possible. Come and join in the AGM with us, have your say and tell us what you think. See you there, Steve
If you have the original Robin Hood wishbones the geometry wasn't exactly perfect to say the least. There was no adjustment for caster angle so, depending on how it all went together, it may not self centre very well at all. Check your toe-in which is adjustable - a small amount of toe-in might help and also make sure nothing is tight or binding on the steering. There are ways to significantly improve the front suspension, including an upgrade kit from Kit Spares, but none are a "quick fix". Steve
Hi Darrell, I'll be there, all being well. Probably only be able to make it for one day myself - Saturday is favourite at the moment. I'm guessing you'll be coming past me (from a global point of view) so I might tag along with you if we're going on the same day. Steve
Anything is possible but I don't know to an easy fix for this. The position of the original arches was (to some extent) down to the builder and they are probably only held on with pop rivets which should be fairly easily to remove. You can then fit alternative arches in GRP or even carbon fibre depending on how much you want to spend - I've see Locost style advertised for less than £100, Caterham carbon fibre ones will cost you a bit more! However, whichever you go for you will have to do a bit of "fettling" to make them fit. The chances are that your side panels will not be deep enough when you lower the arches so some sort of in-fill will be required, unless you replace the side panels as well. There may well be someone on here who's actually replaced theirs but I think most folks have kept the "standard" ones fitted. Steve
I'm repeating myself but again ......................... Welcome to you all, I'm sure you'll find something useful within the club. Ask those questions and we'll help if we can. There will be plenty of shows or meets coming up very soon so get those cars on the road and we'll see you there. Steve
Hi Al, I'm very tempted but I haven't got the car back together yet and I'd need to be sure it's reliable before running it that distance. Assuming everything goes OK I'd like to go but I can't say for definite yet.
I took my tin top in for it's first MOT a couple of days before the end of August and the expiry date shows as 31st August so I would think you should be OK taking it early.
Just bought myself a ticket - I'm hoping I've got the car sorted by then, otherwise it's a very long walk
