tractor
Everything posted by tractor
  1. replace both rears with GAZ shocks if you cant find the AVO ones GBS sell GAZ shocks
  2. did you adjust the sender to fit the tank
  3. if you are running the standard zetec fuel rail then the regulator is part of the rail if my memory is still working
  4. this is a stunning car every detail done to perfection and is an absolute bargain if i hadnt already got two kits aaaah
  5. choke cable about a tenner on ebay
  6. have you blocked off the air correctors
  7. one of the many kit manufactures should still sell them
  8. is it the one with noggin out that you require
  9. yes keep the catch tank high
  10. keep as intended the front needs two because of the extra braking needed at the front
  11. hey i have managed to book a pitch
  12. glad you have sorted it out
  13. on my st170 block it had a nogin stinging out right where the engine mount needed to be so i had to space the mount off the block with the bolts going through some tube in the end Dean rudkin had some laser cut for me he did do a couple extra i will have a look in the garage over the weekend i have posted some pictures of the engine mount plates i have left the two with the nogins out one is twice the thickness of the other and the third one i think is the o/s i have posted them on the facebook page yours if you want them
  14. my ticket is a kitfest weekend ticket !!!!!
  15. sounds like a great idea
  16. i am camping
  17. if you want a run down of parts and tips on installation i will be happy to oblige or maybe you want to find out for yourself half of the enjoyment of an engine conversion is banging your head against a brick wall or is that just me
  18. i used the retro ford self weld engine mount kit if you still have a brake servo fitted thats got to go
  19. If anyone turns up at campsite I am at the pub the malt house at the end of the road
  20. DONT KNOW HOW MANY AS I HAVE NOT TAKEN DEPOSITES THIS TIME ITS JUST A TURN UP THING
  21. ITS ON THE FIELD IS DRYING OUT A REQUEST FROM THE SITE OWNER IF YOU ARE BRINGING A KIT CAR PLEASE KEEP THE REVS LOW WHEN ON THE ROAD LEADING TO THE CAMPSITE THERE ARE NEIGHBOURS COMPLAING ABOUT NOISE SO PLEASE PLEASE KEEP THE REVS DOWN THANKS
  22. got the phone call today its on on on JUST ONE REQUEST IF YOU ARE BRINGING YOUR KIT CAR PLEASE KEEP YOUR REVS LOW WHEN YOU TURN ONTO THE ROAD LEADING TO CAMPSITE THERE ARE HOUSES THERE AND THE SITE OWNER HAS HAD COMPLAINTS ABOUT NOISE
  23. the vauxhall vxr engine will give you a lot of power
  24. unfortunately if the weather dosent improve quickly this event may get cancelled due to the field being so water logged i was there this morning not good
  25. i used sierra rear calippers and pads and focus discs i did have a set of brackets that you use to convert drums to discs i am sure GBS sell them
