hi guys
I have a problem with my 2ltr pinto efi. It runs, starts and drives as it should when cold, but as soon as it gets a little temperature in it it looses power and pops fire  down the exhaust. Ive swoped all the usual culprits ie plugs, leads , distributar cap, rotar arm, fuel filter, checked timing changed fuel (as it stood for many years) have i missed something silly. As i drive it out the garage its on full power, turn it around and almost have to push it back in. could it posibly a coil breaking doown. has anyone experienced the same problem, any advise welcome.
My first thought was coil. Had it on a tractor once, an old ferguson. It took me a while to realise that the miss fire was less noticeable when the tractor was turned so that the wind was blowing on it! It would be worth trying a different one to rule it out.
On a pinto EFi there's a valve type thing (can't remember its name) on the inlet plenum. When left it can start to stick and give symptoms similar to yours, it needs removing and cleaning with carb cleaner.
Worth a try as it's an easy fix (It's held on with 2 nuts/bolts and has a wiring plug connected to it)
HTH
Nick
HTH
Nick
Thanks. Have looked at this it seems to be opening when the cars running which I believe it should. But the symptoms still there. Will take it off anyway and clean thanks for the advice.
10 hours ago, IanS said:
Tappet gaps to small?
Valves warm up and get longer and no longer close properly.
Worth checking but a long shot.
Thanks will check them after I've changed coil. Thanks again for the advice.
12 hours ago, lotusseven7 said:
Mine was a coil issue breaking down when Hot, had new coil fitted runs like dream now.
Cheers going to change it and see what happens.
Quick test for coolant sensor, onnce the engine is warm and showing the symptoms described, unplug the sensor and short the pins of the connector with something like a 2kohm resistor, that will emulate the signal from the sensor when the engine is hot.
I doubt it’s coolant temp but worth checking if only to eliminate but popping and banging in exhaust is generally unburnt fuel in exhaust.
Coolant would cause rich running but not unburnt so start on ign side of things.  Plugs coil etc. Don’t be fooled into thinking it’s as car warms it could just be something breaking down after a few mins of running not changing as coolant warms
In my experience Pinto EFI ECU adds a LOT of fuel when it thinks the engine is cold, enough to cause incomplete combustion, loss of power, and unburnt fuel i the exhaust.  It could also cause fouling of the plugs which make the whole thing worse.
I had a issue on my pinto efi, kept getting high tick over changed everything checked everything. It was the coolant temp sensor. Probably the cheapest part to change, but I had to buy long 25mm socket to get it out.
