  1. Tap the 3-dot menu (â‹Ū) in the top-right corner of the browser.
Foz
Committee
Everything posted by Foz
  1. Foz replied to Andi's topic in Chit chat
    Hi Andi, I'm not sure what category I'm in but thanks anyway, ðŸĪŠ. Same sentiments from me too 👍
  2. Welcome to our new members, happy new year to you all and best wishes to everyone for 2025.
  3. Foz replied to Al04's topic in Engine
    That definitely doesn't look right to me. I'm no expert on blacktops but I'm sure that the bearing shouldn't move like that. Are you missing a washer or spacer from the tensioner assembly ? I certainly wouldn't start it until you've sorted it out. I'm sure somebody on here will be able to answer this better than me but you may have to wait a while for a reply because people don't visit the site as often at this time of year. Steve
  4. Yep, figure out where about the lowest point in the spring seat is when the car's sitting level and drill a hole.
  5. Foz replied to Filpool's topic in Engine
    I'm sure there are a few folks on here who can offer some advice but they probably won't visit the site very often at this time of year so you might have to wait a bit for a reply. Sorry but I don't know a great deal about the Zetec engines.
  6. Foz replied to Filpool's topic in Engine
    Have a look at this thread - If you read through I think a Focus manual is recommended.
  7. There used to be several people who advertised shortened sumps, one used to advertise on eBay - I have no idea if anyone still does. If you want to have a go yourself have a read of this https://nw.rhocar.org/buildtips/sump.htm You can swap a pinto sump without removing the engine, if it will come out between the chassis rails (I don't know if it will on yours) but it's a lot easier to do with the engine out and turned upside down so that all the gasket bits stay put while you bolt the sump back on.
  8. Silver button ........................... press to test, release to detonate ?? ðŸĪĢ
  9. Me again, I've just had a quick search through the forum and found some posts suggesting the early sliding pillar chassis had some differences which meant you couldn't just add the standard wishbone set-up. Have a search for sliding pillar to wishbones, there's plenty of info. but how much will help you I can't say 😃
  10. Hi Dan, yes the 2B wishbone chassis had box section cross pieces which the wishbones fitted to, but the original geometry was out and there were several ways people corrected it - usually with different top wishbones. The kitspares design is effectively the factory way of doing it. You'll see they also do an upgrade kit for the original wishbones. I've managed to find this picture which shows the front chassis of the original 2B wishbone model - compare it to your's to see the differences. The upgrade is normally to the top wishbone and it's connection to the hub. Chassis2.pdf
  11. Hi Dan, If you're making new wishbones you really need to copy the later versions, not the original ones supplied by RH. The original type had incorrect geometry and gave adverse camber when cornering hard, the later design (there were several versions) corrected this. ThanasisPolitis is the area secretary for your end of the world - it might be worth dropping him a message to see if he knows any members who can help you. Steve
  12. I don't know to any plans for the panels but somebody might. GBS (Kitspares) may be able to make you a set but I'm guessing they wouldn't be cheap. Always worth asking the question though.
  13. I've just had another listen and Bob could well be right. Sadly, whatever it is, I think it's going to have to come apart to find out for sure.
  14. Ooh 'eck, that doesn't sound too sweet. It sounds a bit like a little end knock to me. First question, what oil are you using ?
  15. Hi Jon, Do you know what make of coil-overs you have fitted ? RH & GBS used to do a set of GAZ ones for the 2B (don't know if they still do). If yours has a set of GAZ ones I think you should be able to get new bushes for them. Dave at DamperTech should be able to help 01709 703992. If they're not GAZ post up the make and somebody may well be able to help. Steve
  16. Both Adrian Flux and Heritage support the club so it's worth giving them a call and asking the question.
  17. I don't know of any build manuals but this might help
  18. It's not uncommon for Sierra stalks to play up, especially if they haven't been used for a while. Switch cleaner often cures them. It's well worth getting hold of a Haynes manual for the Sierra, there's usually a few on eBay for reasonable money. I've attached a copy of wiring details up to 1987 which might help, items 94 &102 are the stalks. Good luck, Steve Wiring.pdf
  19. Foz replied to a post in a topic in Fitting & bodywork
    Hi Roberto, The kit for your 2B was supplied by Robin Hood Sports Cars who were eventually bought up by GBS - https://en.wikipedia.org/wiki/Robin_Hood_Engineering The 2B required quite a lot of input from the builder to make the kit in to a car so you are unlikely to find 2 the same however, I think most of the nosecones should be the same (assuming it is an original Robin hood one). GBS supported the 2B for a number of years and so they would be the best people to ask how easy it is to fit a Zero grille in to a 2B. Sorry if this isn't a straight answer but hopefully it helps. Steve
  20. I'm not sure you're going to get any updates in the near future, Ant_Harvey hasn't been on the site since June 3rd. If you've got any questions shout 'em up - chances are somebody on here will have some answers. Steve
  21. Hi George, Have a read through this post :- Hopefully it will give you a few answers to your question. Steve
  22. The pinto in my 2B had a CR of about 10:1 and ran nicely with a Kent FR32 set at 108 degrees. As they are all balanced I suspect your low compression figure may be a red herring, I think I got a compression figure around 13 bar (190ish psi) but I had Webers not bike carbs and its easy to open them fully. Have you tried what Trev suggested ?
  23. Does it run any better now or are you still having the same problems ?
  24. Foz replied to Steve potts's topic in Wanted
    Hi Steve, I'm just finishing off the latest edition of the club mag. & I'll happily stick a little article in for you - it might help. If you want to PM me with any info. you have & maybe photos ? Steve
  25. I've had problems with distributors in the past where the body of the distributor doesn't make good contact with the engine block (normally due to a bit of corrosion), and also there is usually a flexible wire from the points (sensor) mounting plate, connecting it to the body of the dizzy, which I have seen broken. A quick resistance check from the mounting plate in the dizzy to the negative of the battery should read pretty much short circuit - if it does then all's good and ignore my ramblings 😀
