blue
Everything posted by blue
  1. Your 100% right there is always going to be clashes but it does not have to be at the bank holiday weekend it can be held ANY weekend the point I was making is LOTS of people / companies will have made other plans there is STAMFORD - oulton park - Chris evans car fest etc ALL on the same weekend and not to start a bebate about it but stoneleigh is a crap show anyway every year it dies a little more -there’s no feel to it there’s no buzz. The kit car companies staff stand there looking bored - CBS now don’t bother even having a stand just dad standing there taking a few orders and handing out magazines and every year there stand gets smaller - look at the year before last , half the hall closed off with a fence to try make it look more full then it is. The other main hall had to have cars inside , charity stands etc and coffee stands to try fill the space ABS TOOLS took up 9 rows of floor space if he decides to go to another show and reduce his presence everything will fit in hall one ! why not have come back with a bang ANY weekend not competing with some long established VERY good shows
  2. I know it’s been a strange year and a half but to host it on the same weekend as a lot of other big family oriented shows I fear it’s gonna be a ghost town at stoneleigh
  3. Morning mark. Are they Weber 45s. If so order a new set from WEBCON it’s the new 5% ethanol fuel the new ones made by WEBCON are ethanol proof.
  4. Where did the gearbox come from? There are a couple of various although rare types of this box which had a setup called a low lift clutch this was something tried by Ford but was soon dropped as customers were complaining of crunching when changing gears.
  5. blue
    Gaz shocks
    Hi yes the 16s are for the rear.
  6. 0k hard to be 100% sure without hearing it but the screeching is prob the alt belt not tight enough and when the alt is under load it’s slipping. That’s why when plugged it it’s drawing current not supplying
  7. blue
    Gaz shocks
    Hi the 15s are gone. The springs on the 16s are 250lb
  8. blue
    Gaz shocks
    Hi the springs are 7’ long. 2.25dia
  9. blue
    Gaz shocks
    Ok yes one knob adjustment thought it was just rebound
  10. blue
    Gaz shocks
    Hi yes standard body. yes adjustable rebound. I will look and confirm if I have the springs on sat. 100% sure I do but want to confirm
  11. blue
    Gaz shocks
    Hi I have A pair of 15" Gaz shocks -£100 A 16" pair of Gaz shocks -£100 think I have some springs also for these but need to find them had these on my 2b but upgraded to ATR as I was offered a deal I could not turn down
  12. You might be lucky with Granada ones but chances are your going to have to take some measurements and suck it and see. The thing is not many fords were rear wheel drive then. Apart from like escorts but completely different setup but if you need to buy some great British sports cars have around 200 oil Sierras knocking about
  13. I thought great British sports cars sold them.
  14. Hi yes I have a single Weber carb /manifold set up and am interested in a twin 40s setup. Please PM me
  15. Agree that map needs a little tweak. Some of the numbers are lower then the corresponding numbers. 11 /15 /14 /17. But dam good as a base to tweak to get someone started.
  16. blue
    Pinto won't start!
    Ah ok. So sounds like you have fuel getting to the carbs. Look through the carbs <might need a mirror >. Open throttles can you see fuel being pumped in ?? screwdriver in the end of a plug lead placed on rocker cover a- does spark jump from screwdriver to rocker - Yes - spark is fine ———no —-check spark an engine even with piss poor timing will still try to start agree spraying so brake cleaner etc in the carb mouth is a 2 sec check to see if it’s fuel.
  17. Hi air con and power steering both come off then you need to buy an aux pulley from someone like retro Ford or poss GBs. This bolts if looking at the engine above and to the right of the water pump. I’ll try and find a pick and post it.
  18. blue
    Pinto won't start!
    Hi. On the video is that the fuel pump I can hear at the very beginning. If it is the loud clicking is because there is no fuel inside the pump. The pump will quieten down when it’s full of fuel. you can hear it’s trying to start
  19. blue
    Miserable failure
    You get these in machine mart. Amazon etc
  20. blue
    Newark kitcar show
  21. Remember a shock NEEDS rebound and compression a spring that holds a shock at the full extent of the travel will drive HORRENDOUS
  22. Ok can I ask you say it floods. So do I take it the plugs are wet ? Plumes of black smoke while it’s running bad smell of petrol ?? What are the symptoms you actually have please.
  23. I’ve done it a few times. a few of us get together and make a day of it. I took my zero , friends had a McLaren /Shelby mustang Gt800 , BMW i8 /Lamborghini and a few others I can’t remember we had a great day and are booked again for this year as the tickets were carried over from last year.
  24. One IMPORTANT thing to remember with the zero suspension arms is the tubes inside the bushes MUST not be able to turn - the bush must spin on the tube NOT the tube in the brackets. So weather you fit the washers or not the bolts MUST be tight to grab and hold the tube
