Big Jim
Big Jim last won the day on August 19 2017
Big Jim had the most liked content!
4 Followers
    Mark 3, Vauxhall powered.
    Jim Stott
Contact Methods
  • Website URL
    http://nw.rhocar.org
    Chorley Lancashire
  • Interests
    Royal Navy WW2 re-enacting, Growing old disgracefully
20,103 profile views
Big Jim's Achievements
Wheely good builder!
Wheely good builder! (4/6)
83
  1. Big Jim
    shortend sump
    The oil should lie clear of getting whipped by the con rods, if you're not sure about your dipstick (And Ford in their wisdom made several dipstick & tube lengths for the Pinto. Buy one of these from Burton Power. (will suite a shorten sump) 'Dipstick & tube'.
  2. After 21 years of being a Hoodie, and several years as the NW area sec, my heath has decided that it's time to say goodby to the Hood, so I'll be bringing it to Stoneleigh on the Sunday to sell it on. See you all there.
  3. Don't need it back. Once you've sorted out for yourself, you might think to run a few off either with the corsa caliper settings, or copy the sierra settings. I'm sure others might want to do similar.
  4. In the post to you
  5. this plate is for the sierra calipers from the sierra 4x4 that had discs on the rear, not corsa
  6. Message me your address https://www.dropbox.com/s/0lczguhlu09z2qo/20190201_095302.jpg?dl=0
  7. Message me your address
  8. Can you get plates cut out if you had a sample? plasma cut or similar?
  9. As previously said, 1mm cutting disk, but once you've marked out (over tape) where you want the cut, clamp a piece of bar or similar straight edge along the line then you 'rub' along the bar with the side of the disk as you cut.
  10. check out this link, http://nw.rhocar.org/dashboards.htm
  11. firstly you need to decide which monocoque model you have, many people call their cars "S7" but that was only used for a very short time as Caterham took RH to court to get him to stop using it. go to http://nw.rhocar.org/identification.htmto find out which model you have, but be aware there were a few "one-off" whilst he experimented with different things.
  12. I still have the sierra sender in the tank, but bent and fiddled with the float wire until I got the best out of it, now it reads 3/4 full when it's actually full, but as it drops down below 1/2 it's actually spot on, so when it reads empty, you really need to pray that there's a garage around the corner.
  13. How to wire the electric fan. http://nw.rhocar.org/fan%20wiring.htm
  14. Valve clearances on a Pinto are ; Inlet = 0.008" (8 thou) Exhaust = 0.010" (10 thou) if you've set them at 20 7 25, it's no wonder they rattle.
  15. The cheapest glass cleaner that you can get from the supermarket. Windowlean etc will leave smears. The stainless has a film covering it, so you don't actually clean the metal itself, just the surface of the film.
