owlman2222
owlman2222 last won the day on February 17 2016
owlman2222 had the most liked content!
    super spec 05 supercharged 2.0l zetec
    jonathan wright
    warlingham, surrey
18,398 profile views
owlman2222's Achievements
Wheely good builder!
Wheely good builder! (4/6)
53
  1. How are you trying to tune it, To tune my zetec supercharged silvertop it has to go to rolling road, unless you are extremely skilled and then you could maybe do it on the road but very dangerous, What issues are you having ?
  2. I can kill a brand new battery in a week, by not keeping it in its operating range, Agreed sounds more like a Potential starter / connection but only mentioned testing it as its easy and you have access to battery , too rule it out before going for a more difficult too access starter
  3. My zetec spins quicker then that, Do you keep battery connected to smart charger when not used ? Lead acid battery's don't like to go dead, plates fur up and you lose performance of the battery If all cables bypass/ tested, I would test voltage when cranking to see if you have an issue with battery not being able to deliver the power, Battery capacity might be ok but the ability to deliver high currents might not, Boost pack or another battery connected if you don't have a meter or current clamps, If that's passes Then start looking at starter, could be short in coil, Start with the easy reachable stuff first then dig deeper slowly ticking off any possible issue like connection
  4. Sorry couldn't make it, was hoping to but family commitments, hope to be at the next one
  5. Has been done before, when I first went to Stoneleigh kit car show a few years ago now there was an electric car using lead acid battery's, I beliver you have a couple of options, Mount motor to gearbox and use gears, Mount to rear dif or direct to wheel, lastly being the better option but might need 2 motors. Will need to get LIFP04 batteries, these come in different form factors.so depending where you going to place them. Would need to pick your motor size and voltage, then speed controller for the motor then match the batteries to the motor, Would suspect you will need to be up in the 110vdc to 200vdc range to keep the current down so you haven't got 1 ton of cabling Would recommend doing plenty of research on it, would be an interesting project
  6. Would require deep cycle batteries if you want them too last a long time, car batteries are designed to give a big instance load of current then be topped up, where you require long charge time and long current drain, as a short term solution a car battery would work. When setting up battery size, length of time lights will be on for X current draw off lights will = X, is dose not mean you need X as the battery size, X is your float value which is about 20% of the total battery (depends on batteries), so you had 2 amp draw on lights and you would have them on for 2 hours, you require 4 amps to run them, so not to destroy and shorten the life of you batteries you will need at least a 20amp battery. but this will only allow for 1 day, during the winter this would cause a problem as lack of light to charge the batteries, As I don't know your set you whether your using a gird tie system or a back feed system. deeming how much solar to point to the battery's depends of type and voltage arrangement of your solar set up but a good rule is 20% to 50% of the power of panels generated in winter time. If it was me and you had a 12v solar rig, I would point all of the solar panels at the batteries allowing you to use a smaller size battery then use a charger controller to divert the solar panels back into the house once the battery's are fully charged. This means you keep the battery's toped up and once there full it goes back into the set up you have at the moment.
  7. +1 for coolexerts just got my new rad from them, top quality rad with top customer service, and really quick turn arround of custom 70mm rad, they even waited for me to send them my fan so they could fit it where i wanted it on brackets they made.
  8. what type of injectors you after.
  9. got a wining twin screw IHI or if you want to join me i have a spare AMG C32 and charger cooler that i am bolting to mine :crazy:
  10. yep 200v or 400v dont know how the power feed and dro are wired but normally they are all connected into the termanal box on the side wich will then feed the power feed and dro and motor. then adjustments in the motor termanal box to alow for 400v or 200v. when you get the serial number of the machine will be able to get wiring dirgrams. depends if you want a motor spinning a generator in the cornor to create 415v, yes more then 1 device can be installed to a rotary but there is no controll over the output. ditigal can only really have one machine conected to it as you set it up to that machine, but you have a lot more control over that machine.plus are more energy efficant.
  11. Rich need to know more about the machine before we can tell you what 3 phase converter to get, as said above most 3 phase is 415v but you can get several other voltage specs. most new 3 phase motors will run on 415 or 240v 3 phase. if memory serves me corectly, will have to check when i am at work tonight but the conector box to the motor needs 6 termals in it, if you only have 3 termals its a 415v motor only. if you have 6 termals in the termanator box the converter above will work. when looking at convertors make sure it has a soft start, this will start up the motor in a way to limit in-rush current, so you dont get a spike of current and keep blowing breakers and a instance high torque curve on the belt and bearings. other option is to fit a single phase motor so theres no need to get a 3 phase convertor.
  12. I don't get theses calls no more, might have something to do with a virus being infected on there computer. I use team viewer all the time, great program for helping mates outs from my own home.
  13. The screwdriver type test light will only light up when it is put onto the positive leg, the reason why its lighting up in the negative leg is because there is no negative supply and you are getting the positive through the light bulb, take the light bulb out and the screwdriver light will go out, Please do me a favour and throw that screwdriver away and buy a volt meter don't need to get an expensive one, The reason I say that is, if the screwdriver creates a fault internally from misuse ( hit with hammer or thrown into tool box) you could be on the end of a nice shock. I suspect you have got a broken core on the negative, look around where the lights are fitted for brittle or hard to bend wiring caused from the heat off the lights. If you use a muilt meter you will probable see 40 to 50 volts indicating a loss of one of the legs negative or positive. If you are unsure get a sparky in.
  14. Good qualitly through crimps, that are see through so you can see wire position in the crimp, crimped with corect crimping tool not a universal, then heat srink with corect size heat srink, this alows for the wire to be left straight without any bends. Best pratics it not to crimp or solder but to have continus wire. Bomb crimps are designed to insolate a cable core that can not be removed, not to joint 2 wires togesther.
  15. owlman2222
    House Woes
    angle grinder every time, you can get some lovely wavy cuts, so the bonding grips it better, well that's my excuse
